55 inch DLP Powered itself off and will not turn back on, receiving 6 pulses of beats on power led. Please advise. Will not power back up manually or by remote.
Sony 55 inch DLP will not power back on. Shut itself off and will not pwer up again. I get 6 pulses of red blinks from the power source. Please help and let me know why I cannot power up anymore. It clicks every five minutes or so. Please advise. Thanks, Steve
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash ok Steve can you tell me what model of tv it is please and do you have the user manual for it ,, also is it a LCD projection tv or a tri tube type .. if it is an lcd type the blinking lights usally mean the lamp has gone .. if it is a tube type it means there either is an electrical power supply problem or a flyback problem .. Regards Vortash
  • Michael Masters
    Michael Masters May 11, 2010
    when do you hear these clicks?
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
Posted on Oct 16, 2008
mistersony
  • 320 Answers
SOURCE: Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Posted on Oct 19, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
welcomejee
  • 10594 Answers
SOURCE: sony wega 55 inch tv turns on fine but after one
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Posted on Oct 30, 2010
Testimonial: "Thank you- this answer was Very helpful !"
Toshiba model 62MX196 t.v. 62 inch rear projection...turns on then goes black and mute after 5 secs then red led continually blinks. Unplugging and rebooting power button causes a voice to say "fan st
I'M ASSUMING THIS IS A DLP? IF SO "ANY"
I REPEAT IF ANY OF THE FANS ARE SEIZED OR DRAGGING
SLOWER THAN THEY ARE SUPPOSED TO
IT WILL SHUT DOWN THE Tv!!!!! EVERYTIME AND THAT GOES FOR ALL OTHER DLP/LCD PROJECTION AS WELL!
BY DESIGN THEY DEPEND ON THOSE FANS, WITHOUT THEM THEY WILL BURN UP THE PARTS THAT THEY ARE ASSIGNED TO COOL. THE 3rd WIRE ON THE FAN PLUG SENDS A PULSE EVERYTIME THE FAN COMPLETES A 360 degree REVOLUTION, TO A CIRCUIT THAT MONITORS IT.
Nov 15, 2013 | Toshiba 46H84 46" Rear Projection...
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
55 inch tv shut off will not turn on any more
velvel535, since you do get the other led's to light up it could be that you have an operable power supply and the problem is more than likely in the horizontal deflection circuit' a shorted h.o.transistor or components related to it.If the tv does have a good power supply you will hear some kind of noise when you push the power key though this is not a sure indicator of a good power supply. some repair costs for a horiz out problem can run up to 290 dolls depending on the problem.Please leave positive feedback if i answered your question.thanks!
Aug 27, 2009 | Hitachi 55FX48B 55" Rear Projection...
A pulsin sound from the subs
You don't give us much to go on...
Are your subs self-powered? Disconnect the Line In to see if that makes the pulsing stop. if it does there's some kind of signal coming from UPstream or a cable has poor shielding. If it keeps pulsing something's wrong in the sub's power amp(s).
Isolate that much and come back.
May 12, 2009 | Audio Players & Recorders
I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Mar 03, 2009 | Samsung HLT6176S Television
Why does an HDMI cable make a difference with my TV's operation?
NO THERE IS QUALITY, COMMUNICATION PRORTOCOLS AND TRANSFER RATE
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
