Question about Sony ICD-P210 Digital Voice Recorder
Turning Off Recorder
I need to turn my IC Recorder off (ICD-P210). I don't want to place it on hold I want to turn it off completely without taking the bateries out (if possible)? There is no on/off button and I don't want to waste my batteries..Please help!
  • thinmilk17 May 25, 2009
    No, it did not work. I turned hold off and pressed the little stop button underneath the select option on the recorder but it did not turn it off! =(
    Awe man, that sucks! If I keep it on hold and just turn ff the screen will it drain my batteries. I usually place it on hold and then click the Play/Stop button and the screen goes blank...does that mean it is off?
Yes. Putting it on hold and then pressing the stop button will turn off the recorder. You can turn it back on by taking it off hold. It is technically off even though when you press a button while it is off it tells you that it is on hold. Don't worry, your batteries are safe for now =).
Posted on May 26, 2009
    Problem Solver:
  • 4 Answers
First, make sure your lock button on the bottom of the right side is in the off (down) position. Then, if your unit works like mine, simply push the stop button twice to turn the unit off. You turn it back on by pushing the play button. Hope this works for you.
Posted on May 23, 2009
Can I use my ICD-P210 on Windows 7?
No, this IC Recorder is not compatible with the Windows 7 Operating System. In other operative system, could download the drivers from Sony Site Donwload
Hope this helps (remember to rate this answer)
Jun 30, 2011 | Sony ICD-P210 Digital Voice Recorder
Does ICD-P210 work with Windows 7 ?
Well the answer is Yes, you need to download driver's for window 7.
Good Luck!!
Thanks for using FixYa!!
Mar 27, 2011 | Sony ICD-P210 Digital Voice Recorder
Hi, I have a Macbook Pro and I'd like to use my ICD-P210 sony recorder: is there any drivers for it? Thanks Imane
Hi imane_bu,
did you find an answer? - I also have a MPB and have been offered the ICD-P210.
Peter
Dec 17, 2010 | Sony ICD-P210 Digital Voice Recorder
MY SONY ICD-ST10 RECORDER IS STUCK WITH AN "ERR ACCESS" MESSAGE
I try this solution but it didn't work! I can select WHOLE but I can't select DELETE from the menu.
How can I do for restore the data storage or for delete all and formate the IC recorder?
Dec 10, 2008 | Sony ICD-P210 Digital Voice Recorder
Sony IC Recorder icd-p210 how do you turn it off?
The hold button on the right hand side . Just slide it forward and it will go off. forward means if you are holding it, in your hand facing your slide it up ..
Sep 09, 2008 | Sony ICD-P210 Digital Voice Recorder
Turn off
slide it into the hold position. itll turn off after 3 seconds
Aug 09, 2008 | Sony ICD-P210 Digital Voice Recorder
Sony ICD-P210, ERR ACCESS message
Your problem may have been caused when you removed the unit from the PC without using the "safely remove hardware" option.
What you need to do is download the latest version of Digital Voice Editor (I think we are up to 3.1 now)
When you connect the ICD unit it will probably give you a number of access errors
Ignore them and go to the IC Recorder Menu. Select WHOLE and DELETE. Delete everything.
After a minute or so the unit will come to life and you'll see the Directories that are standard in your unit.
Remove the hardware from the computer (safely! by closing the program first) and turn the unit off.
Now turn it on...... Bingo!
Apr 01, 2008 | Sony ICD-P210 Digital Voice Recorder
My IC recorder P210 says ERR ACCESS
Remove the hardware from the computer (safely! by closing the program first) and tirn the unit off.
Feb 26, 2008 | Sony ICD-P210 Digital Voice Recorder
Digital voice recorder completely 'locked-up'
Any time an electronic device lockup there is two main reasons. The first is a data error. A data error happens when incorrect digital information enter certain IC chips, and cause the chip to lock up. This is sometimes called system busy. Similar to when a computer freezes up due to corrupt software or a computer virus. To fix you remove all power to the IC chips. Removing the batteries is not enough, due to the fact that circuit boards have components on them that hold voltage. Additional batteries, coils, capacitors. You have to remove the covers and take the main digital board out. Check to make sure there is no other battery on the board. Some boards have an additional battery source for storing date and time and other info. remove that battery. Either short all capacitors and coils. or let them dissipate, sit for a day of two . Install board back in machine this should clear any system busy type problems. If the problem remains, the digital IC chip or chips are bad and have to be replaced. So boards may have a way of reset the circuits. A technical manual or a call to tech support is required.
May 04, 2007 | Sony ICD-B200 Digital Voice Recorder
Sony ICD-P210 Digital Voice Recorder Logo
563 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
