Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Compressor hums and won't start - Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
Motor hums but won't start
Most problems with humming motors are with the power input TO the motor (Not enough power to turn the motor)
I'm guessing it is a single phase compressor? If you have it connected to an extension lead, then, if you can, try plugging it directly into the wall, (you can lose vital power through the long lead itself) Second the capacitor attached to the motor could be on its way out or shot. You would need to get it tested, or if you notice anything bulging out of it, then you know it needs replacing. If all the above are ok, then you would need to get the motor itself checked out by an electrician, the bushes or coils are probably gone
Hope that helps
Sep 10, 2012 | Air Tools & Compressors
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
Cambell Hausfeld model wl506201aj compressor Hums when switched on
This could be caused by one of two things:
- a stuck or broke tank check valve. This would be evident if the compressor starts up when there is no pressure in the tanks but only hums when the tank pressure is up. Some valves can be cleaned and will work for a while but they usually have to be replaced.
- motor start capacitor. If the capacitor is bad it won't get the motor spinning, with or without pressure in the tanks. You can test it by taking the shroud off the pump and carefully bumping the motor to get it turning. Be careful, it may run up to full speed right away. If it runs replace the capacitor, if not you may have a burnt or shorted motor.
Apr 11, 2012 | Campbell Hausfeld Air Compressor Check...
I have a CH 8 gal compressor that won't run. When you turn it on it just hums for a couple of seconds then stops. You hear a click and then your able to turn it on again but it still just hums
Remove the air out line and the motor. Try to turn the motor and the compressor by hand. You have a seized bearing somewhere. Bearings are available at any power transmission shop for a few dollars.
Feb 04, 2012 | Campbell Hausfeld Air Tools & Compressors
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
My compressor is very hot and not running or kicking on, it was making a load humming noise yesterday and my freezor is not freezing?
It is cycling on overload and not starting. you can try a "hard start kit". If it still won't start then the unit must be replaced
Jun 24, 2011 | GE 18.0 Cu. Ft. Frost-Free Top-Mount...
Motor hums dont start
sears craftsman air compressor motor hums. replaced start capacitor still hums
Mar 13, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
47 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
