Question about GE Profile WPSR3100W
Washer model wpsr3100w1ww - GE Profile WPSR3100W
2 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
Is 10194450 the model # of my whirlpool washer
Hi Adrian, no this number is not a model number for a Whirlpool Washer. If you have a top loading Washer, you can locate the model/serial number by looking just under the lid around the tubs rim. If you have a front loading Washer, the model/serial number can be found by opening the door and looking around the opening of the Washer. The model number will begin with letters, usually with the letter W. We hope this helps.
Apr 05, 2017 | Whirlpool Washing Machines
GE Washer Mod. WPSR3100W1WW Ser. RV120 945G Tub seal(s) defective, especially on larger load settings. Am unsure of dis-assembly process. Apparently housing must be detached and lifted off working...
yeppers to all of these..you would be well served to grab a service manual on this item, before proceeding. Also, you may wish to enquire of GE, as to parts availability.
May 12, 2008 | Washing Machines
Tip
How to receive the best washing machine repair help on FixYa
There are a couple of things that you should include in your washer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the washer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of washers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your washer.
Descriptions like 'My washer don't work' is not very helpful.
Describe what is not working. For example is the washer not filling with water? Maybe the washer is full of water but it will not pump the water out?
The more details you can give the better. Instead of saying 'The washer will not pump the water out' you could go into more detail and say something like...
"My washer filled up with water and started agitating. When I went to take the laundry out of the washer the timer had advance to the end of the cycle, but the washer was still full of water. I advance the timer around to the drain cycle again to try and drain the water out of the washer, but all the washer does is make a humming sound."
Following these couple tips can help you get a faster and more accurate reply to your washer repair question.
on Aug 03, 2011 | Washing Machines
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Whot is wpsr3100w1ww capacity ?
Refer your inquiry to the manufacturer/distributor.
May 11, 2014 | Washing Machines
GE Topload Washer WPSR3100W1WW -- finished spin cycle, clothes were spun as normal. Water on the floor after spin cycle. When jiggling tubs, we can hear there is some water still in machine. Bottom metal...
That is normal. The balance ring has liquid in it. # 327
On these machines the tub is suspended with 4 metal rods. The lateral movement is controls by 4 straps. When these stretch the tub gets loose and water slings out the washer. Seen it.
Training Manual
This video shows how to take the whole thang apart:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 18, 2010 | Washing Machines
Can't remove agitator
Get 2 2x2 pieces of wood or 2 oak handles, 20 inches long. lay on on top of the other on the top of the washer. Loop a rope or ******** both sides of the agitator over one of the pieces of wood and tie it to the top piece of wood. Twist the top piece of wood slowly. As the 2 loops tighten up under the agitator the bottom piece holds the rope firmly across the top of machine. This save you from getting socked in the face by the agitator when it come off. You can buy an agitator remover but why not make you one and have so much fun doing it See the pic below? just ease a stick above the 2x4 and start slowly twing till she jumps out. Note: I didn't make this design I found it on line. I would run the rope under the agitator instead of taking a chance on breaking the fins. But that's just me.The trick is to grab it by the neck instead of the base. So try that before concocting a agitator remover. The agitator just snaps on. The drive block under the agitator is stripped out Wh43X10009 91c45a0.jpgis the part number. Here it the manual3c3b88a.jpg
May 25, 2010 | GE Profile WPSR3100W
GE Washer WPSR3100W1WW the agitator is very lose and water is leaking down into the gearbox.
Thank You for contacting Fixya.com
Inorder to fix the agitator I would request you to please follow the step by step troubleshooting mentioned in the bellow mentioned link:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Have a nice day.
GodBlessU
Sep 10, 2009 | Washing Machines
Ge profile washer WPSR3100W1WW won't agitate
Aug 21, 2009 | GE Profile WPSR3100W
Burning smell from ge washing machine wpsr3100w1ww
either the belt or the motor are wearing out on it
Jan 08, 2009 | GE Profile WPSR3100W
Washing Machines Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
