Question about Pioneer VSX-823-K
Vsx 823 factory reset - Pioneer VSX-823-K
HOW TO STOP ADDVANCE MC ACC LIGHT FROM FLASHING?
your unit is in protect mode. Try pressing and holding the power and advanced surround buttons. This should turn it on. If it shuts right back off, then you probably have a short in the amp that needs to be repaired.
Jun 13, 2014 | Pioneer VSX-823-K
HDMI light flashing
Unit is in protect mode. Hold "advanced Surround" button and power switch for a couple seconds and it should turn on. If it turns back off, disconnect all your speaker wires and try again. If it still shuts off, the amp is bad and needs to go in for repair.
Apr 02, 2014 | Pioneer VSX-823-K
HDMI light is flashing
The unit is in protect mode. Try pressing and holding the 'advanced surround' and power buttons. It should power up. If it shuts down again right away, there is a problem with the amp that needs to be repaired.
Mar 25, 2014 | Pioneer VSX-823-K
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
How to reset VSX 8000 to factory default - Forgot the password
RTFM!!!
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
May 03, 2009 | Polycom (VSX 8000/VORTEX EF2280 ) (Bundle)...
Factory reset
put a paperclip in the front just below power button and turn unit on. this will factory reset it.
Oct 25, 2007 | Polycom VSX 7000 Video Conference
Pioneer VSX-823-K Logo
404 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
