Question about GE Spectra JBP84 Electric Kitchen Range
Ge duel burner range small inside burner doesn't work
Ge duel burner range small burner does not work on either large or small setting
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: cooktop burner doesn't switch between small and large
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch.
The switch for your appliance has part number:
WB21X5243
You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace.
Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
Regards
Posted on Apr 07, 2008
  • 22 Answers
SOURCE: Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Posted on Mar 14, 2009
  • 512 Answers
SOURCE: GE range two large burners do not work. The two
Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
Posted on Aug 22, 2009
richroth
  • 9472 Answers
SOURCE: the large burner in the duel burner does not work
Either there is a wire loose on the dual burner switch, or the switch is bad. Here is a link to the switch in case you need to replace it.
Posted on Feb 04, 2011
Cooktop burner doesn't switch between small and large
WB21X5243
Regards
Apr 06, 2008 | GE Spectra JBP78 Electric Kitchen Range
How do you replace large element on dual burner? How do I remove the glass top?
the duel element is just that
a duel element, when you order the replacement it will come with both burners in the circle
the top comes up after you remove the srews under the lip above the top of the door
unplug this before youy toch anything
then write down where each wire connects on the burner and reconnect them the same way on the new burner padles
Oct 15, 2009 | GE JBP80 Electric Kitchen Range
Burner on stovetop is out
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
Aug 22, 2009 | GE JBP30 Electric Kitchen Range
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
Open Questions:
See all GE Spectra JBP84 Electric Kitchen Range Questions
GE Spectra JBP84 Electric Kitchen Range Logo
37 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
