Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung hdtv hcn4226w
Tv worked last night in the am didnt, last 6 mo. had squiggle lines in it , took it to a tv repair shop 60.00 buck and 2 weeks later he called said he couldnt get the part and for me to call samsun , i did they dont make the part anymore. part number is BP41-00045B , I found the part at partstore.com for 9.95 but it doesnt match my tv . tv man also wanted 280.00 bucks at first to fix it . any ideas for me? thank you
    Genius:
  • 1,139 Answers
Hello tcoop,
It sounds like you had a convergence problem. You made a big mistake, you may not have had to replace the board only repair it, or at least the parts on it. Granted that skill is dying these days. Ok I cut to the chase, to find someone to repair the problem is not going to be your problem, your problem is going to be finding someone to do it under 300.00, 280 was letting you off cheap. Right now I have 10 convergence boards in my shop repaird tested and ready to be put back in the lowest one is $295.50. If you want to take on the task of doing this yourself ok here is the advice you seek:
1) get a schematic of your TV www.servicemanuals.net  may have it
2) get a multimeter
3) optional equipment Oscilloscope, and Universal Video Analyzer
4) solder iron and desoldering tool (solder sucker)
Using the schematic as a guide measure the bias resistors and zener diodes to make sure they are ok if they are not replace them.
The desolder the 2 Convergence Correction Amplifier chips (STK392-110) and replace them with two new ones or upgrade to the STK392-150s.
After installing the two new correction amplifiers, reconnect board and test. Using the oscilloscope to look at the waveforms making sure they are correct as per the schematic. The Universal Video Analyzer is supplying the test reference signal.
Now if you don't have this equipment and do not have a background in electronics. The only option is to pay to have the board fixed.
There is one other option:
Finding someone who knows how to fix those boards here on fixya.com who is willing to fix yours at a reduced rate.  The question then becomes what price under $280.00 are you willing to pay? The ball is in your court, so as to say.
Not trying to sound mean or hostile, I am just trying to get you to see that boardswapping got you into this mess, but what you should have been doing is finding someone who knows what they were doing at a component level. 280.00 is a good price for the labor and the possible parts involved.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 19, 2007
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
Whats the life time of a lamp for a hd tv
these could go for along time or not soo long depending on how many hours is on it. if it spends all day and night on it might last 5 years.
Jun 21, 2010 | Samsung HCN4226W 42" Rear Projection...
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
TOSHIBA TV- HCN4226W convergence PROBLEM
I charge 285.00 at my shop ,so if you cannot fix it your self you are looking at repair anywhere from that price or more .You have 2 STK ics these are your convergence Chips .You would need to replace both of them.If you can solder you have it made.
Dec 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Lines moving through out picture
can't give tech help ,but can tell you we have same problem and having a hard time finding an anwser /someone to come out to look . actually had a repair shop ask me to bring it in (yeah all 85 lbs.) will try calling place that repaired it when it was under extended warraunty thru best buy. took 1 mo to get the part back then. did you see my post on wiggly lines. good luck
Apr 04, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Samsung projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Dec 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Black Lines
yea my 50 inch hdtv is the same. i contacted the samsung number since its still under warranty and they said i need a new engine or something for my tv that they would come out next week to fix it. i guess it happens alot. but they said once itf fixed it probably wont happen again. so u should call them
May 11, 2007 | Samsung HCN4226W 42" Rear Projection...
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Feb 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
210 people viewed this question
Jerry Greenberg
Jerry Greenberg
