Question about Whirlpool Ovens
Cooling fan will not turn off - Whirlpool Ovens
Whirlpool cooling fan will not turn off ovens
There is a thermostat usually on the top or back of the oven which controls the cooling fan. When it cools down, the fan is supposed to turn off. I would say this thermostat has failed. Locate the thermostat and if its cool, the thermostat should be open circuit. If not, you will need a new one. Most spare parts centres should carry these. A generic or common oven cooling fan thermos will suffice if you cant get the genuine one. make sure the oven is off at the wall or the fuse box before you go into it.
Nov 19, 2016 | Whirlpool Ovens
Whirlpool built-in electric single oven makes a whining noise after it is turned off?
Most of them are equipped with a cooling fan designed to keep the controls from melting... Once it is warmed up, the fan runs until the fan thermostat cools enough to power it off... Cooling Fan W10127321
Jun 29, 2016 | Whirlpool Ovens
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
79 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
