Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer vibrates with exhaust hose attached
I have a GE Harmony electric dryer. The drum was replaced less than a month ago. It now makes a very loud vibration that sounds like it is coming from the back, near the bottom. When the exhaust hose is removed from the dryer, the noise stops. The exhaust hose appears clear and air is vented to the outside. Putting the hose back on the dryer causes the noise to return.
  • Anonymous Mar 30, 2014
    attaching vent hose
  • 1,543 Answers
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
Posted on May 21, 2009
    New Friend:
I am having the same issue. Did you find the solution?
Posted on Jun 20, 2013
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
My harmony dryer makes a very loud vibrating noise and does not heat sometimes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trsyw
Jan 21, 2010 | GE Profile Harmony DPGT750EC Electric...
Ge dptg750ec make loud rumbling noise after replacing blower
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Blower motor access
You cant you have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DRYER STOP RUNNING
sounds as if the belt has snaped and the drum has droped stopping you moving the drum
Dec 05, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
162 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
