Question about Sony Grand WEGA KFE50A10 50" SDTV LCD Projection TV
Lcd blinking green
When I turn on my tv it comes on for about thirty seconds and then shuts off blinking green about thirty times then turns back on and continues with the same pattern
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
SOURCE: light blinks 8 times
I did a last minute search to do the repair myself before I called somebody. I found this and figured "This will never work!"
I followed his suggestion and now my TV looks better than it has in months!!! I'M SO RELIEVED!!!! Although I really want to upgrade to a flat screen LCD or PLASMA but I'm not ready for the expensive. I have had this SONY for about 6 years!!
THANKS TVDUDE!!!
Posted on Feb 08, 2008
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
  • 195 Answers
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
  • 1525 Answers
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Posted on Oct 25, 2009
The Visio on front blinks orange and white with black screen
The tv is powering down when flashing. Hold the power button down for thirty seconds, this will shut the power down completely. \do this after you unplug it. than plug it back in. it will still blink but only for a few seconds then you should be able to turn the tv on
Jul 27, 2012 | Vizio M470NV 47 in. LCD HDTV
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Screen turns green The picture and sound are fine when I turn on the tv. After about thirty seconds the screen turns green and then turns off and the power light blinks.
Sad to say, but that's one of the ways a picture tube can behave when it's gone bad. After it warms up, one of the wire elements in the neck of tube sags and touches something it shouldn't. As a result you're seeing the green screen, and then the set shuts down for safety because of voltage feeding back. The only way to repair the set would be with a new tube, and that's completely uneconomical. You can buy a new 32-inch LCD set now for less than the price of a new tube, not including the labor to install the replacement and get the color alignment (convergence) set up.
Mar 08, 2011 | JVC AV-32F704 32" TV
Tv is on every thirty seconds it will turn off for thirty seconds light begins to blink and then it comes back on by itself. the tv does this of and on every thirty seconds
"LAMP"LED light indication blink?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?Tv on and used like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 11, 2010 | Sony Televison & Video
Tv shuts off and led power light blinks
Turn off/on couples times,power it well come back on stable,if not ur video board it dead.
Dec 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony Grand WEGA KFE50A10 50" SDTV LCD Projection TV Logo
11 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
