Question about Garden
Stihl FS55 has no spark - Garden
3 Suggested Answers
plink_plonk
  • 1807 Answers
SOURCE: Need Stihl FS55 parts diagram. Thanks!
Standard carb settings for stihl equipment: screw both needles in, then turn anit-clockwise L- 1 full turn H-3/4 of a turn.
Posted on Aug 29, 2012
AndrexT
  • 20941 Answers
SOURCE: My Stihl FS55 Trimmer gets a small amount of white smoke under full throttle, is that normal?
I recategorized this for you.
Yes, I would say that is normal as they are two stroke and burn oil to lubricate the piston, bore and crankshaft. If it smokes, you know it is OK. At full throttle it needs more oil.
Posted on Oct 30, 2015
I need a repair manual for a Stihl Fs55 trimmer
I have the same trimmer,just got finished using it on my yard,What's wrong?My off switch doesn't work,I just turn the choke switch to close to turn off,these models all have this problem,and I just went to the Stihl dealer and bought a new bump head for less than 11 bucks,the other one worn down from dragging on ground and holes got in it causing dirt to get in and string not advancing,works great now,also removed air filter and cleaned with hot dawn soap water and tooth brush..I have the owner's manual.If you need a new spark plug,take to AutoZone and get new one,Stihl dealer is very high on spark plugs.Click on link on my other comment for a manual.
May 29, 2017 | Stihl Garden
Fs38 Stihl weed trimmer extremely very hard to pull with sparkplug in but no problem with no plug.
A hard pull on that unit would indicate a sheared flywheel key. The key is part of the flywheel. Check to see if there are 'rub or scrape' marks on the outside of the flywheel. Adjust coil clearance to .010". Coils on those models are normally very reliable. Use a spark tester for lawn mower engines. Preferably with a light in the center of the tester wire. If it its an adjustable tester, adjust the gap to at least .065 to 0.85". The light tester should produce a bright orange light, the adjustable tester should produce a bright blue spark. I cannot find specs on those models, as dealers use the 'light in wire' type tester.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 07, 2017 | Stihl Garden
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
How to remove clutch from Stihl fs81 brushcutter?
go google and type in --workshop manual for Stihl brush cutter model fs 81 -- and download the pdf version from the stihl site
Feb 08, 2016 | Stihl Garden
Which is the high low settings on a stihl fs55. Weed eater?
there are three holes in side cover one has an l for low one has an h for high and the third is your idle
Sep 09, 2014 | Garden
Fs55 will not idle down
If you have the idle screw turned out all the way and it still runs fast, the saw is sucking air from some where. Check the carburetor gaskets. I work at a Stihl dealer as a mechanic and what we find most of the time is the air is sucked into the saw thru the main crank bearings. This is a costly repair to replace them and can only be diagnosis-ed by performing a vacuum and pressure check. Thanks. George
Jul 12, 2012 | Stihl Fs55 Trimmer Manifold / Intake 45 46...
Stihl FS55R Carb Diagram
I found user manual on amazon, so you can take a look there: Stihl FS55 Instruction OEM OEM Owners Manual Paperback 1983 cheers
Mar 27, 2012 | Stihl Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
