Question about Samsung Ln32d403 32 in. LCD TV
Tv turns off and on with led blinking - Samsung Ln32d403 32 in. LCD TV
Samsung led tv troubleshooting guide
i have 65 inch samsung tv LED UA65D8000XN if you plag in red light on if you tuch power ON was blinking then the blinking it will stop but the tv will not turn ON the tv no display no picture relay click about once per second but the tv will not turn on thanks for any solution
Aug 22, 2012 | Televison & Video
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
How do i get this remote programed to work with my television?
I hope this would help you.
1, Turn on the tv.
2. On the remote control, press the tv key once.
3. Press and hold SET until the LED blinks twice, then release SET.
4. Use the code to locate the typ of device and brand name and then enter the first four digit code for the device. If performed correctly, The LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the tv and press power once. The TV should turn off. If it does not repeat steps 2 to 5. trying each code for your brand until find one that works. If it doesn't work, try searching for you code.
BTW, I don't know the brand of your tv so you might as well try these steps to search for you code but if you want to use the steps above just reply to this and send me the brand of your tv so i can search for the code.
1. On the renote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 9 1. The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
5. To lock in the code, press and release SET. The LED will blink twice.
Jun 10, 2010 | One For All URC-6131 Remote Control
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I need the codes to program it to my orion tv and the onefor all website is useless
The Orion TV codes for the URC-3021 are: 0236 and 0463.
To control an Orion TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0236 or 0463
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
If that doesn't work, use the auto-search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Nov 19, 2009 | One For All URC-3021 Remote Control
Need code for programing
Manual is available at One For All here
http://www.oneforall.com/uploads/support/6c8b036cd3ba3806d00e5a1c57409ef0.pdf
To set up remote
1. Turn on TV.
2. On remote press TV key once.
3. Press and hold Set button until LED blinks twice
4. Enter first 4 digit code for your TV manufacturer from the manual above (P.18). LED blinks twice if code has been entered correctly, if not go to 2.
5. Press Power and the TV should switch off, if the TV doesn't switch off go to step 2 and repeat with next code for your brand until TV does turn off.
Searching for code
1. Perform steps 1 to 3 as above.
2. Enter the code 991. LED will blink twice.
3. Press Power button.
4. If TV turns off
Press Set - LED will blink twice.
If TV doesn't turn off
Press TV button and go to repeat step 3 and 4, until TV does turn off.
Check a code.
If you've used the search function you might want to know what the code is to do this...
1. Perform steps 1 to 3 from set up remote at the top.
2. Enter code 990, LED will blink twice.
3. For the first code press 1. Wait 3 seconds and count the times the LED blinks, that is your first digit, if the LED doesn't blink that is 0.
4. Repeat step 3 for remainder codes, pressing 2 for second digit, 3 for third and 4 for fourth.
It doesn't state in the manual how to get out of this mode but normally it is either leave the remote alone for 5 minutes, or press any other button other than 1 to 4.
Nov 10, 2009 | Televison & Video
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
4) Enter the code 0154.
If it does not turn off, try the auto-search function.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Samsung Ln32d403 32 in.  LCD TV Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
