Question about Sportsart 6300 Treadmill
Elite euphoria treadmill incline motor gets very hot while running then brings up e6 error
2 Suggested Answers
SOURCE: E6 error - incline not
I'm getting the same E-6 error while running in program mode although the fuse is fine - and when I recycle power, the program starts fine again and then stops in the middle with the E-6 error. Nor sure what's wrong. Just sandpapered the fuse ends and the connector ends to the fuse socket. We'll see how it goes.
Posted on Jan 20, 2011
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
Error code E6 (XQB70-DB14)
24 Hour Locksmith Local Locksmith Locksmith Cheektowaga Ny 716 710 7399...
Aug 07, 2016 | Heating & Cooling
I have strength master treadmill when I put in on it show me E7 please what is the problem
May 03, 2016 | Exercise & Fitness
Horizon Elite 5.3 treadmill blows JP2 fuse. Incline does not work, all other functions work even with fuse blown. Does not blow if I disconnect incline motor.
Great work! Another great point for treadmill servicers! Please be aware....inside a treadmill lift motor, there is a small potentiometer or pot, that watches the "throw" or position of the lift screw, which relates to the treadmill incline. These lift motors have a sheath or "nut" on the screw that MUST be set properly at the ZERO degree mark of the deck, for proper operation from zero elevation to 12% or whatever it's uppermost incline is. This must be assembled correctly, or like in this case, that motor begins to "pinch" at one end of it's "throw" and the current will rise in the winding and blow a fuse, saving the lift from burning up. Nice job troubleshooting Thad!
Feb 05, 2016 | Horizon Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Treadmill marquee mt8.12, e6 error. looking for owners manual
go and download free www.fitnessmanualsonline.com
causes: key safety+ elevation motor connection+screw binding.
solution: repair or replace s. key + test the connection e.motor + clean and lube the screw e.motor.
God bless you
Jan 08, 2013 | Exercise & Fitness
Hb pioneer pro treadmill gone to full incline with E6 fault code, how do i fix it
Please RUN the software calibration instruction is UNder the hood motor cover. and follow steps. this is for diagnose, troubleshooting and fix it.
then lubricate the gear and shaft elevation motor.
God bless you
Aug 05, 2012 | Exercise & Fitness
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
E6 error - incline not responding. Replaced 1A fuse but still not working
Dec 14, 2010 | Sportsart 6300 Treadmill
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
Sportsart 6300 Treadmill Logo
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
Sportsmith LLC
Sportsmith LLC
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
