Eject before disconnecting - Audio Players & Recorders
Toshiba undock
Hello Eleanor,
By your question I can not tell if you have used the docking station or not so here is the removal procedure for a Hi Speed Port Replicator II
To disconnect the Port Replicator, follow the steps below.
1. Set the computer lock to the unlock position.
2. Make sure you perform
one of the following:
• Save all your work.
• Turn off the computer's power in any mode: boot, suspend or hibernation.
• Perform any software disconnect operation required by the operating
system.
• Press the eject switch.
CAUTION:
Make sure the Eject LED is out. Do not try to disconnect the
computer while the Eject LED is glowing.
3. Pull the eject lever out towards you to disconnect the computer.
4. Lift off the computer
Now if there are further problems or this did not help you please post further information like at what step did the station not perform correctly. Hope this helped.
Nov 29, 2013 | Computers & Internet
I am trying to connect leapfrog leapstar to computer and follow application but when I connect usb with computer the leapstar says Please click "Eject button" Where is the eject button? I've...
The Eject button appears when a Leapster2 handheld is connected and turned on. When you have finished configuring the Leapster2 handheld and your child wants to play with it, you can click the Eject button to disconnect the device. Once ejected, a message will appear letting you know that it is safe to disconnect the Leapster2 handheld from the computer. It is not really a "button" but a picture of a green button which says "EJECT". It should be located on the upper right corner of your screen.
Sep 20, 2011 | LeapFrog Leapster 2 Learning System
My ipod is says eject before disconnecting
i have an ipod classic  it used to do that     now i can just disconnect without ejecting since it has received several software updates   previous to that if i unplugged the ipod before ejecting the ipod froze   online i learned how to reboot the ipod if it froze
Nov 07, 2009 | Apple iPod nano
How do I eject my nano ipod before I disconnect from the computer
on your itunes there should be a picture of the nano on the left side bar of itunes with a little button beside it... click on this button to perform the eject feature
Oct 18, 2009 | Apple iPod nano
The instructions suggest that one click eject before disconnecting. Where do I find the eject button?
what are you trying to eject i'm assuming cd
cd right click cd drive and click eject
Jan 23, 2009 | Computers & Internet
I have a nano 8GB- How do I load pictures onto it?
1. To load pictures onto your ipod, you need the itunes software which will easily allow you to put photos onto your ipod.
2. When you get the itunes software, it will have an option in the list where your ipod will be listed for you to eject your ipod. It will be a symbol that looks just like any regular eject button. You could also eject your ipod by going to my computer and right clicking on it, and in the list, select eject.
To get the itunes software, you can go to this website and download it: http://www.apple.com/itunes/download/
Dec 30, 2008 | Apple iPod nano
This screen will not move on Do not disconnect, after it was connected to computer using windows vista
if it shows this you must eject the ipod first...click on the little eject button beside your ipod in iTunes, or, go into my computer (in Windows), right click on your ipod icon, and click eject..hope this helps
it might also show up as an icon in your system tray (bottom right corner of your screen if you are running windows). It should say something like "click here to eject usb drive"..
Mar 16, 2008 | Apple iPod nano
Do Not disconnect message
if you don't eject the iPod, that is what will happen.
to eject it alternatively, what you should do is go into control panel\system and find the device manager.
You should find it under removable drives. click it and and select disable.
Then it should be ejected.
hope this helps.
Oct 08, 2007 | Apple iPod nano
LG KG-800 with Mac OS X (eject issues)
First scan your mobile with anti virus and then format your mobile next connect and add files and close all the programs running and refresh your system and then click eject or in taskbar click on safely remove hardware and disconnect it.
Aug 10, 2007 | LG KG800 Cellular Phone
112 people viewed this question
 Grubhead
Grubhead
