Question about Samsung Digimax 530 Digital Camera
Samsung digimax s500 keeps saying check sd card
I put in a new card and after it says format, the only option is yes. So I hit yes then it says check sd card. what can I do to solve
  • 370 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
  • 161 Answers
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Posted on Sep 09, 2009
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
  • 11967 Answers
SOURCE: keep getting card error message while trying to
Is the slide switch in the unlocked position?
Posted on Feb 16, 2010
Obertelli
  • 3006 Answers
SOURCE: I bought a 4GB Memory Card for my Samsung Digimax
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Posted on Mar 23, 2010
SOURCE: comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Posted on Jun 05, 2011
My samsung S500 has suddenly stopped recognising the sd card
Try formatting the sd card IN the camera. Never format an SD card while it is in the computer.
Jul 22, 2016 | Samsung Digimax S500 Digital Camera
Sd card wont format
Are you sure your camer supports 8 Mb? Check your manual. If you don't have one, download it:
http://www.manualslib.com/manual/418879/Samsung-S500-Digimax-5-1mp-Digital-Camera.html
If it is supposet to support 8Gb SC cards, get a microSD card USB reader and insert it in the computer. Can you ree it as Remvoabvle disk?
It the computer won'r recognize your card, it is BAD.
If you can see it, try to format it to FAT32
Again, if can't, card is BAD
Jun 08, 2015 | Samsung Digimax S500 Digital Camera
Is sony sdhc compatible with samsung digimax s500?
The S500 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 04, 2014 | Samsung Digimax S500 Digital Camera
Do all sdhc cards fit a samsung digimax s500 camera
Apr 03, 2014 | Samsung Digimax S500 Digital Camera
Sdhc card will not load onto my samsung digimax s500
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
Mar 01, 2011 | Samsung Digimax A7 Digital Camera
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Sep 09, 2009 | Samsung Digimax S600 Digital Camera
My samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
Oct 16, 2008 | Samsung Digimax 530 Digital Camera
Samsung Digimax 530 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
