Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
Toilet dual flush adjust - Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
3 Suggested Answers
  • 760 Answers
SOURCE: Caroma dual flush toilet is only 2 years old and
Try this link for adjustment instsructions:
http://www.caromausa.com/site_assets/www.caromausa.com/images/dynamic/pdf/QuietFlow%202%20Service%20Guide.pdf
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: how do I adjust the
By moving the float
Posted on Oct 25, 2010
Toilet flushes but bowl won't fill up
Adjust the level in the tank. It should be filled to the level mark on the rear of the tank. Adjustment is by the screw on the float, or lever depending on which country you are. Some tanks are Dual Flush, small flush for waste water (short press), long flush for solids (press and hold). See the link.
Google
Dec 27, 2016 | Home
I have a Kohler dual flush cartridge toilet and on small flush there isnt enough water being released to wash any paper away. We have two toilets like this and one flushes much more than the other. Can the...
not really as the flush time is set by the manufacturer in the design
what can be adjusted is the water level in the cistern
the more water , the longer the flush before the reset ( shut off)action is activated adjust that by the float screw ot water level adjust screw on the inlet stem
Feb 27, 2015 | Kohler Home
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Feb 19, 2010 | Kohler - Toilet - Two-piece - Highline -...
Toilet won't flush - water drains very slowly
YOU COULD HAVE A BLOCKAGE IN YOURE LINE OR IF YOU ARE LUCKY YOU JUST NEED TO ADJUST THE CHAIN THAT CONCTS THE Handle to RUBBER STOPPER IN THE BACK OF THE TOILET THIS WATER IS CLEAN AND YOU CAN PUT YOUR HAND IN THE BACK PART OF THE TOILET WITH NO WORRIES JUST TAKE OFF THE LID AND FLUSH IT OBSERVE THE RUBBER STOPPER IN THE BACK OF THE TOILET IS IT COMING ALL THE WAY OUT
Jan 19, 2010 | Toto Aquia II Dual Flush Toilet
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
468 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
