Question about Directed Electronics OHD1020B Car Video Player
Can't get DVD to eject, is there a force eject button anywhere?
Ejecting a cd from a computer that has crashed
Method 3 - Force Eject Next, you can try to to force eject the CD/DVD tray to open. Not all drives and burners have this feature. To check to see if yours does, look near the face of the CD/DVD drive and you should see a small hole.
Use a toothpick, bent paperclip, or needle to push the button. This may or may not pop open the drive. Many people have reported that this does not work. But some have reported that it does.
or try this link.
CD or DVD Drive Won Eject or Open
Nov 03, 2017 | Computers & Internet
Tip
Force Eject CD/DVD From a Macintosh Computer
Have you got a CD or DVD That won't eject from a Macbook or Mac desktop?There are many ways of getting a disk to eject. 1) Log Out: then try by pushing eject on the login screen. 2)Login: If that doesn't work login and push eject. 3)Restart: Restart the computer and repeat steps 1 and 2. 4) Force Eject: To force eject hold down the mouse or trackpad button when the computer is starting up, if you have a non-apple mouse hold down the left click. 5) If All Else Fails: Your disk drive could be broken you should call Apple or take it to the shop you purchased it form with your applecare box and number (if you have one).
on Dec 21, 2009 | Computers & Internet
Tip
Force Eject
If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
on Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
My Toshiba VCR & DVD video recorder model D-VR4XSU won't eject a DVD disc from the player, neither by pressing the eject button on the remote nor by the eject button on the players console.
A temporary solution would be to use a paperclip to eject it; usually, any disk drive has a little hole that a paperclip can be stuck into which forces it to eject.
Mar 04, 2011 | Toshiba Televison & Video
I tried to eject a DVD and now the DVD holder is
if you had forced it open its probably not aligned (if its still open give it a little shove and press the eject again (otherwise unplug the machine for 5-10 min..and try pressing the eject button again
Jul 09, 2010 | Toshiba D-VR4 DVD Recorder/VCR
Sony blue ray player won't eject DVD
I have a new Samsung Blue Ray player. I cannot figure out how to eject the DVD. Can anyone hepl me. I do not see an eject button on it anywhere.
Apr 10, 2010 | Sony SLV-D360P DVD Player/VCR
I placed a dvd in the driver the wrong way round wont eject
Hello Dear,
You can always eject the Drive bay, forcefully, if it is not eject by pressing eject button.
To do so, find the small hole just benethe the CD tray, get a needle like thing and insert it into the whole, you cd tray will come out, now you can get it out by holding it by hand.
Thanks
Feb 02, 2010 | Apple iMac OS 9.1
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Tray will not open
put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
Apr 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Directed Electronics OHD1020B Car Video Player Logo
27 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
