Question about Yard Machines Heavy Machinery
Briggs free repair manual
Very high idle how to adjust
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Could you tell me where I could look for a free
This may be of some help to you.
http://engines.myfaqcenter.com/Answer.aspx?p_faqid=3353&selectCats=Troubleshooting - Repairs
Posted on Jun 13, 2010
ssimons47
  • 13145 Answers
SOURCE: need free repair manual for briggs 5 hp engine on maxim tiller
get your engine number and go to briggs website.
Posted on Jun 25, 2017
Briggs and stratton push mower idle set to high....how do i lower it
if should have a screw on the top of the carb that can adjust the idle speed turn right increases it left decreases it.
Dec 28, 2017 | Briggs Garden
Looking for a 445677 Free Repair manual
I don't know about a free one..but try eBay and put your model and manual there are many in there...but before you try that try adjusting your carb..out of adjustment air/gas mixture acts that way also..locate the adjustment screw and at about half throttle adjust it clockwise until it starts to bogg down the the other way until it Boggs again..keep adjusting back and forth until the engine runs the smoothest then add some throttle and repeat if it needs it...good luck..
May 17, 2014 | Briggs & Stratton Garden
Adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Apr 26, 2012 | Briggs & Stratton Garden
2007 Honda SCV 100 Lead high idle
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Faulty automatic choke.
8. Broken throttle return spring.
9. Damaged diaphragm or slide.
10. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
11. Multiple carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://crfsonly.com/forum/viewtopic.php?t=22201
Rincon 680 low idle high idle info
SVC100 LEAD 2003 HONDA SERVICE REPAIR MANUAL Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda SCV100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 22, 2012 | 2007 Honda SCV 100 Lead
2011 HONDA CRF150R HIGH IDLE
2007 Honda CRF150R at idle
How to Adjust Idle On Dirt Bike Tips and Tricks 1
CRF150R service manual repair 2007 2014 CRF150RB Download Manuals Technical $150
Honda CRF 150RB Owner Manual
Jan 25, 2012 | 2011 Honda CRF150R
Do they all 5 hp briggs boat moters jump around when they shift or is there somthing I am doing wrong thank you
Your idle speed is to high. These have (most of them) a wire wound round a drum for the clutch (called a bendix clutch) and it is very positive. so your idle must be real slow not to damage. it. If the engine will not run slow it's most likely problem is mixture adjustment after that would be the bottom seal.
Aug 16, 2011 | Briggs & Stratton 5 Hp Outboard Service...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Aug 20, 2009 | Briggs & Stratton Garden
Heavy Machinery Logo
50 people viewed this question
Top Yard Machines Heavy Machinery Experts
donald boissonneault
Phil Walker
Phil Walker
gerald martin
Level 1 Expert
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
