Computers & Internet Logo
A
Anonymous Posted on Jan 02, 2014
Mainboard Vestel 14MB02-03 no power - Biostar Computers & Internet
Larry Ng
Level 3:
Top Expert:
  • Biostar Master 14,606 Answers
  • Posted on May 17, 2022
Larry Ng
Biostar Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280275
Points
66651
Posted to computer repair help, PC
what computer is this, not told
Vestel 14MB02-03 (mobo labels useless)
Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.
Vestel does not sell PCs !
google shows no hits (zero). posted wrong PC model?
ahhhhh coded words off mobo white painted silk screens
sure
I see one hit on that number alone and shows LAPTOP PC MOBO
clearly
ok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????
odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorry
the model is on the bottom tab on laptops old
or in bios screen 1 told
now and answer for laptops old.
1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.
2: coin cell dead, sure it is that old replace it.
3: any of up to 20 other modules inside shorted out.
4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?
5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
Hitachi 32HB6J51U no picture; inverter, mainboard or T-con?
It does sound to me like the T-Con. If you can change the channels even though you can't see the picture then that's is a T-Con problem. Especially as you can see the lights. Before replacing any of the boards check for bad solder joints and poor connections between the boards, as the TV does sometimes function right.
tip
Vestel DVD4250D Service Manual Download
Download Vestel DVD4250D Divx DVD Player Service Manual
Have you misplaced your Vestel DVD4250D Divx DVD Player Service Manual?
Would you like a digital, searchable, pdf version of the Vestel DVD4250D Divx DVD Player Service Manual?
Follow this link (& click FREE) to download a pdf version of the Vestel DVD4250D Divx DVD Player Service Manual.
I hope that helps.
____________________________________
on May 03, 2010 • Televison & Video
tip
Vestel DVD4500D Service Manual Download
Download Vestel DVD4500D Divx DVD Player Service Manual
Have you misplaced your Vestel DVD4500D Divx DVD Player Service Manual?
Would you like a digital, searchable, pdf version of the Vestel DVD4500D Divx DVD Player Service Manual?
Follow this link (& click FREE) to download a pdf version of the Vestel DVD4500D Divx DVD Player Service Manual.
I hope that helps.
Who makes servis tumble dryers
the brand was originally made in england but fell into difficulties in 1980
from 1991 to 2008 the brand was owned by italian white goods company antonio merloni they went broke and the brand since 2011 is in the hands of a turkish company vestel who relaunched the brand in 2012 ( refer to wikipidia)
call customercare @ servis .co.uk or direct call 0333-577-7232 go google and type in - location of vestel manufacturing-- and see if you can get some information from their pages as facilities are in turkey, UK,china, taiwan
Apr 25, 2016 • Dryers
Code vestel tv
1061 1052 1423 1051 1007 1032 1012 1177 1145. These are the codes to check with Vestel. If you wish to get more, http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide / Flipcard option.
Comet hitachi tv loses tuning / untunes everytime switched off
Vestel make the power boards... its unlikely that they will help. Your best bet is ebay, look for 'main board'
1helpful
TV CODES FOR VESTEL T845 REMOTE
go please to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
11helpful
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Cannot programme black diamond television.
Your universal remote control will only give you ch +/-,Vol.+/- and mute it will not give tuning or picture controls ie brightness, colour, zoom, the Blackdiamond are usually of Vestel make try searching for Bush,Vestel,Goodmans or try the search for code unknown in the remotes instructions it will operate the TV but please read the instructions carefully.
SUPER8
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
