Question about Haier HVTB18DABB Wine Cooler
Not working right
Lights come on where the number suppose to b and the inside light come on to but the number don't come up just line no sound
Red Light Inside Is Off and No Caller ID
Hi, usually this red light is a "new message" indicator when it's on, the normal condition should be off. If the caller ID function is not working could be cables misconnected, the connector labeled as line should be connected to wall line outlet, the connector labeled as phone should be connected to your telephone. In the worst of cases if the connections are OK, there's a problem with the line or the caller ID unit.
Jun 11, 2013 | Olympia InfoGlobe Caller ID
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
I don't have signal lights, my heater blower inside of vehicle don't work checked all my fuses they were good and tried top set the computer
sounds like it could be a bad flasher and for the fan there is a fan relay i would suggest checkin that out
Dec 07, 2012 | 1994 Ford Explorer Limited
I am trying to find part numbers. I have a Hyundai Elantra 2005. I need to know the radio fuse number, roof light fuse number and clock fuse number. All of them went out.
Am not sure whether you have the Hyundai Owners Manual. If you don't I find it very worthwhile. Section 6, the "do it yourself section" lists page 6-34 and 6-35 for fuse descriptions. Also on the cover of the fuse box in the car under the ash tray left of the driver is a pictogram, but in any case according to my manual radio and clock are both listed on the "audio" and is in the inner panel, the 10A at the top right(next to the spare). Don't know about your roof light - hope you don't take offense but assume you checked the switch just didn't get set wrong, but if it isn't solved by fixing that one, the manual lists RoomLP controlling the inside lights, which is in the bottom (shorter) row on the far right. Of course, this might not help but if it does I could possibly scan my owner's manual page and email it if you can't find one.
Aug 23, 2011 | 2005 Hyundai Elantra
Fthe tail light works but the brake light doesn't work, it probably is the module that has a circuit board. I have replaced it 2 or 3 times on my 2004 XL Envoy ... can I get a part number and location...
First let's determine which brake lights are not working. Does the high mounted brake light work? Do both left and right brake light not work? If none of the brake light work, the problem could be the brake light switch at the brake pedal OR fuse #12 in the underhood fuse panel.
If only the bake lights at the corner lamp assembly don't work, check fuse #34 in the rear fuse panel.
The module your are referring to is the circuit board located in each of the corner lamp assemblies, check on website www.compnine.com for the part number of this item. I don't believe this is your problem though.
Jul 25, 2011 | 2004 GMC Envoy
My lights on my grand cherokee is deem and my inside lights won't go off if my dashboard lights are bright. When I deem my dashboard lights my inside lights can go off
Sounds like your dash light dimmer switch is faulty. It is supposed to allow you to turn off the inside lights and still have the dash lights either bright or dim. Have it checked out and replaced.
Sep 22, 2010 | 2000 Jeep Grand Cherokee
1999 Ford Contour turn signal issues...
not a fuse
if it were the right rear park lamp would also be out
your bulbs actually have two filaments inside
first make sure you have the right bulb
second check for power on the orange/green wire
Mar 21, 2010 | 1999 Ford Contour
The igniter comes on but will not light the oven
The ignitor is supposed to allow enough of a spark to light the gas. It sounds like this isn't allowing the gas to light so it's probably your gas valve that's not working on this unit. If you will call or email us with the brand and the model number, we can send the proper part to you. We hope this answers your question and this should do the trick for you. Ellawatson25@yahoo.com. Looking forward to working with you.
Aug 26, 2009 | Ovens
Turn signal
check to see if the bulb is good and if it is replace the flasher located under the dash.
Oct 26, 2008 | 1991 Cadillac DeVille
Haier HVTB18DABB Wine Cooler Logo
75 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
