Question about Garden
John deere troubleshooting
Starter only clicks but has new battery
4 Suggested Answers
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
nova2nv
  • 197 Answers
SOURCE: John Deere 316 the starter doesn't engage often.
You need to instal a starter relay kit.Deere part # AM107421.Mount it down by the starter,purple wire that goes to starter will now be plugged in to the relay,red wire to hot side of starter,black wire to a ground point,purple wire that is a part of new relay can now be plugged in to the starter.its very easy to install and fixes nearly 100% of clicking starter.
Posted on May 29, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
John Deere Z225 starting problem. The solonoid only clicks when I turn the key.I replaced the battery, the starter, the ignition switch and the starter solonoid!
With everything you have done only 2 things come to mind.
1) Safety switch open or not functioning.
2) Engine seized.
May 03, 2017 | John Deere Garden
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
John deere 5075E TRACTOR WON'T START BUT BATTERY GOOD AND MAKES ACLINKING NOISE FUSES ARE GOOD TOO
I Am Guessing Clicking Is Starter Drive. Can Be Several Causes. Not Enough Amps From Battery--Dirty Connections--Power And Or Ground--Loose And Or Defective Starter--Seized Engine.
Feb 27, 2015 | John Deere Garden
Deere g110 mower, engine will click but will not turn over. New starter. Seems like blades are engaged. How can i tell?
use a pair of jumper cables and go from the battery to the starter see if the starter works try and jump it from your car it could be a bad starter
Apr 05, 2012 | John Deere Garden
John Deere 165 will not turn over. New battery has fuel. Engine clicks one time when I turn the key. Could this be starter or solenoid? How do I trouble shoot?
"One click" tells me it's a connection issue. Remove and wire brush the ground and battery cable connections at the battery, chassis, starter and starter solenoid.
May 22, 2011 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 316 the starter doesn't engage often. Turn the switch get a click, again and again, finally the starter engages. If it doesn't start right off there is another series of clicks before it will...
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
3,432 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
