Question about Empire Comfort Systems Radio Shack 43-330 Cordless Phone Battery 1X2AAA/D - 2.4 Volt, Ni-MH
Setting time on answering machine 43-330 - Empire Comfort Systems Radio Shack 43-330 Cordless Phone Battery 1X2AAA/D - 2.4 Volt, Ni-MH
Setting the date & time
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
Jul 10, 2010 | GE 29875GC1 Digital Answering Machine
Manual for phonemate #2750 answering machine
I was just waiting for the voice commands after preswsing "set time" When I pressed set time It just said "answer the time" it should have said set time by looking at the LCD screen while pressing the left / right buttons. The screen shows you the hours & minutes change. I solved the problem myself. Thanks, George
Nov 16, 2009 | Lands Phones
How to set time on the southwestern bell answer machine FA982B
I went to the southwesten bell freedom phone site on the web. Found answering machines.  My old machine was not listed, so I found instructions for a later machine.
The method for setting time was similar.  I tried it and it worked fine.
Your high prices prompted me to be less lazy.
Jun 10, 2009 | Southwestern Bell Lands Phones
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
I have a GE29869GE2 Answering machine, no instructions anymore. How do I change the number of times the phones rings before receiving the greeting kicks in?
1. Press set button
2. Use next and previous buttons to select number of rings setting and press set.
3. Select the number of rings you want.
4. press set again to save setting.
I hope this helps. Here's the manual:
29869GE2 Digital Answering Machine
Dec 13, 2008 | GE 29869GE2 Digital Answering Machine
Setting the time
You need to select the "set" button after each entry when setting the machine up so it will save your selection. (Day of the week then set, hour then set, minutes then set, year then set).
Oct 21, 2008 | AT&T 1738 Digital Answering Machine
HOW DO i SET TIME ON A 43-3829 ANS MACHINE???
One thing Radio Shack's answering machine [model number 43-3829], is NOT, is intuitive. But I guess you know that already. ;-)
To set the date and time, perform each of the steps below in quick succession, otherwise the machine will drop you out of the process and you’ll have to start over. You have about five seconds between each step, so try and make a mad dash for the finish line (Steps 4.-5.).
Setting Date and Time on Your Answering Machine:
(To set Day…)
1. Turn the answering machine on and hold down the TIME SET/CHECK/>> button until it beeps twice.
2. Press ANNC/DAY/<< repeatedly until the correct day displays / is indicated.
(To set Hour…)
3. Press REC repeatedly until you reach/hear the correct hour.
(To set Minutes…)
4. Press >|| (PLAY) repeatedly until you hear the correct minute(s).
(To Review/Confirm...)
5. Press TIME SET/CHECK/>> once. The machine will play the time and day you entered.
Note:
To exit/cancel the time- and date-setting mode, press ON/OFF/STOP once.
Hope this helps! If you have additional questions, please let me know and I’ll do my best to help.
Gail
Oct 14, 2008 | Radio Shack (43-3829) Digital Answering...
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Aug 03, 2008 | Emerson Em1200 Answering Machine
Setting the time on my answer machine
how to set the time on att 1738 answering machine
Mar 31, 2008 | Lands Phones
Answering machine
1. Press and hold SET for 2 seconds. Then Release. 2. Unit plays Hour announcement. 3. To change setting, press NEXT or PREVIOUS repeatedly. 4. To store setting, press and release SET. 5. Unit automatically advances to next setting. 6. Repeat steps 2, 3, 4 to set and store Minute, Day and other settings. Press ALL or NEW button at any time to stop and exit.
Apr 28, 2007 | GE 29868GE1 Digital Answering Machine
Empire Comfort Systems Radio Shack 43-330 Cordless Phone Battery 1X2AAA/D - 2.4 Volt, Ni-MH Logo
27 people viewed this question
Top Empire Comfort Systems Electronics - Others Experts
Are you an Empire Comfort Systems Electronics - Other Expert? Answer questions, earn points and help others
