Question about Freezers
Water in freezer, runs constantly
Commercial freezer, used. Just started using it. There is water (a quart a day!) dripping down off the top fans and the thing is running constantly.
  • dawnowens May 21, 2009
    Wow, Thanks, you answered quicker than I could check my email! :)
    If you're ever in Battle Ground, Washington, I owe you a quart of frozen custard! :)
    President:
  • 1,136 Answers
Hi, There is a drain plugged. Look on the back of the freezer. If you can not see a drain hose, look underneath. Blow through the drain hose and clear it. If you can remove a panel near the fan motors and get to the drain there, you can clear/flush the drain out too.
I hope this helps you.
Vic
Posted on May 21, 2009
  • Victor
    Victor May 21, 2009
    You are welcome......good luck
  • Victor
    Victor May 21, 2009
    lol..thanks
    and if you are ever in Niles Michigan you still owe me a quart......lol
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every few seconds
In the freeze cycle too long. Usually about an hour. Several conditions can cause this. look for stuck float or constant water running even when machine is off. start there first.
Aug 03, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I turned the power on my freezer as now we decided to use it , before it was working fine it became very hot inside and the fan on the top didnot start?
Too many things can go wrong, but try this first, The fan on the top must be turning got the unit to work. Sometimes when a unit sits up for a while the fan bearings freeze up. Try trurning the fan with your hand of a screwdriver if it has a shroud around the fan. It may start moving and ususally when it does it will be arright after that. The inside will be hot because it will go into a defrost cycle 3 or 4 times a day and that puts a lot of heat inside the unit. Also the door frames are heated. Check to see if the compressor is running. If it is the small copper line going over tt the fan will be very hot. If not its not running. Co to start with clean the radiator coils on the outside and make sure the fan by the compressor is running.
Sep 17, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Why is the ice maker dripping allot of water inside and not producing ice even though the compressor is running?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 21, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Water runs constantly
Update on the above! The water does shut off, but when the water is running it runs and splashes for awhile down all over the ice thats in there. Water bill is very high when it is in use.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
155 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
