Pvr troubleshooting im using the hd pvr 2 and everything is plugged in right its just that the tv has no signal
2 Suggested Answers
chamboard
  • 557 Answers
SOURCE: Do you have to have 2 coaxil jacks when connecting bell's hd pvr?
use scart are better !!!!
Posted on Aug 19, 2009
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
How do I connect DGTEC PVR to Toshiba TV?
Hi Bronwen,
You might want to double check if there is cable loose or not connected to the right slot ( on the back of tv and pvr ).If still not work check the input lists and check one by one and there should be one of them is the right input. Hope it helps.
Apr 27, 2014 | Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Jul 22, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Televison & Video Logo
345 people viewed this question
Top Televison & Video Experts
