Question about Thumper Mini Pro 2 Massager
How do I fix the mini pro2 from having to turn it off and on ony by plug out then in to turn it on. Switches don't work. and when it plug it in, it only has one speed.
The on and off switch doesnt work. I have to plug and unplug to operate...and only one speed works
2 Suggested Answers
SOURCE: Broken Switch on Thumper Mini Pro2
I have the same model with the same problem. Once I got it apart the I rolled up some steel wool nice and tight and stuck it in the switch openings that are clear on top of the switch. I then took a small flat screwdriver and moved the steel wool up and down along the switch until I could see the contacts clean. I moved the switch up to clean the bottom contacts, and down to get access to the top ones. I plugged it in and it works fine in all three speeds. Prior to this I was just getting a hum.
Dave - 905 333 3338
Posted on Aug 29, 2009
Testimonial: "Thank you so much, I will try this asap as I miss the tumper!"
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Where can I get the purple plastic pivoting assembly for my mini pro2 thumper massager
best to call the company & see if they have it available as a repalcement part.
Sep 06, 2012 | Thumper Mini Pro 2 Massager
\windows\system\vgaoem.fon on my dell mini
The ony thing you can try is a system restore of your computer and bring it back before you lost the file, it just might work.
Apr 08, 2012 | Dell Inspiron Mini 1011 Netbook
I ve the palmcorder which when powered it only switches on for seconds then off . what is the problem and how to fix it? The other thing is about the battery am failing to charge, how do i do to the...
Sometimes the batteries for these camcorders just go bad. There's nothing you can do to fix the battery itself, but you can find them really cheap online. If you don't think the battery is bad, and you just don't know how to charge the battery, you can find the manual on Panasonic's site. You can click support, and there will be a place to enter the model number. It will be on the camera, probably on the bottom. If you enter a model number that doesn't fetch results, try a different number (or combination of letters and numbers) until it does find results for your camera. Most of these small cameras have a small door, or attached cap that you have to pop up and open with your fingernail (they are small, so look carefully, most likely around the bottom or back of the camera). Plug the charger in and wait to see if the battery charges. If it does, the Palmcorder will stop turning off a few seconds after you turn it on.
Apr 15, 2011 | Panasonic Palmcorder PV-GS9 Mini DV...
How do I install the standard mini inline cord switch. I am a novice.
The cord has two wires.
Use exacto knife or utility knife with sharp blade, slice the wire down the middle for about 2 inches.
Be careful and don't cut into the copper wire.
Now the two wires are separated, like each lane of a road going around a tree.
Cut one wire completely through. Leave the other wire continuous and uncut.
Which of the two wires do you cut?
Go back to the plug and notice that plug has two prongs. One prong is narrower. This prong carries voltage to the lamp, so technically and officially that is the wire to cut.
However you can unofficially cut either wire and it will work fine.
Open mini switch and there are two halves and one screw that tightens two halves together.
Notice inside the mini switch, there are two sharp brass points.
These brass points will penetrate through the wire insulation and into the copper when you reassemble the mini-switch.
So place your continuous wire in the open mini-switch. and place your two cut wires in place where the brass points will push down, you may have to trim one of the cut wires a bit shorter.
Then put the two mini-switch halves together and squeeze them together between fingers, and then tighten the screw.
That should do it.
If project fails, Amazon offers a work-around:
http://www.amazon.com/Woods-13568-Wireless-Control-3-Outlet/dp/B001Q9EFUU
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
Apr 14, 2011 | Leviton Mini Feed Thru Cord Switch -...
USB mouse doesn't work.
Some USB devises are not compatible with USB hubs. They usually specify that they must be plugged into a main USB. This may be the case with your mice.
Nov 06, 2009 | Belkin OmniView PRO2 4-port KVM Switch
Dave - 905 333 3338
Jun 15, 2009 | Thumper Mini Pro 2 Massager
Direct Access buttons
the hotkeys are funcion becouse the ps/2 manual operation, but you have to claim the waranty fortunatily the omniview have 5 years in both parts and services claim it...good luck
Aug 10, 2006 | Belkin OmniView PRO2 8-port KVM Switch
Thumper Mini Pro 2 Massager Logo
56 people viewed this question
Top Thumper Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
