Question about GPS
Magellan problems - GPS
Magellan 4000 will not boot. freezes up at magellan on boot. black bar loads and then magellan stops
You will need to send your unit back to Magellangps.com or if it is out of warranty, you may contact Auto Nav 2000 Plus, Inc in San Jose and see if you can get your unit recoverd for a fee.
You probably have a internal battery problem or could have been updating your unit when it is not fully charged that will normally cause this type of failure.
Good luck
Apr 03, 2010 | Magellan Maestro 4000 GPS
My magellan gps shuts down as soon as i enter an address the message I get is "devise needs to shut down to update system" How do I solve this problem?
  • Try to update the firmware of your Magellan or call the tech support of magellan and ask whats the latest firmware update they have.
Feb 09, 2010 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Magellan just stays on Magellan blue screen
Feb 18, 2009 | Magellan Maestro 4250 GPS
Magellan Triton 500 value bundle
magellan has a big problem in the past with the Canada Value Pack. It did not work with the Triton. It was only made to work with the older Magellan GPS units.
Best to contact Magellan and see if they will give you a new one.
Dec 29, 2008 | Magellan Triton 500 Handheld GPS Receiver
Magellan Maestro 3250 Regions Problem My magellan maestro 3250 shows the regions,Canada,Alaska.Hawaii,and Puerto-Rico. How can I change to US?
I had the same problem, magellan would not give me a code for the map to just download but did agree to send me a new unit and then have me send back the old ubit after verifiying my receipt. did have to give them a credit card # to make sure I send back the old gps
Dec 12, 2008 | Magellan Maestro 3250 GPS
Magellan 2000 doesn't power up
try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
Jun 07, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Problem with softwear
Warm the unit up. It has an internal hard drive. Very low temps can cause problems.
Jan 27, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 700, lost signal found a causation. Need help
Bin the Magellan - nothing but problems when you need to update or resolve problems.. I am replacing my magellan with a Tomtom Go which does auto updates via a cradle linked to PC.
Dec 16, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
55 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
