Question about Samsung SMH8165STE Microwave Oven
Recall Stops working and SE code shows up
Why is my samsung microwave showing -se-
It thinks it has a shorted membrane switch on the control panel. Unplug it for a minimum of 30 minutes to see if the code clears. If it doesn't, you might actually have a bad switch, and the touch pad might have to be replaced.
Aug 14, 2016 | Samsung Microwave Ovens
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
Feb 01, 2016 | Maytag MMV4203D Microwave Oven
How to fix SE in the control panel of microwave
Remove power and clean the inside while checking if there are food particles on the inside or in the Wave-guides- the portion where the Magnetron is fitted. Also remove the main cover and clean the areas of the Magnetron , check for loose joints,Finally check if the main capacitor is faulty. Other wise you will need a check on the main board, and also the Magnetron for leakage.
Sep 03, 2014 | Samsung SMH9187 Microwave Oven
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
My kenmore microwave is displaying "SE" and will not operate
SE = SERVICE, the Microwave is asking/telling? you to take this unit to be "Serviced" as it has developed an internal fault. (Or so it "Thinks") In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 03, 2010 | Kenmore 62622 Microwave Oven
Samsung SMH8165STE Microwave Oven Logo
48 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
