Question about Dell InspironTM 1501 Notebook
Funtion F8 not working s video from laptop to TV
I rebooted my system and Function+F8 is not working..i am connecting my s-video cable from laptop to tv..dell inspiron model
  • Anonymous Mar 19, 2014
    I want to connect my dell inspiron 1545R laptop with a old model RCA TV 27R411T, My laptop having HDMI port, but my tv have S video and 3 pin RCA (Red, yellow, white) how can I connect it, do I just need HDMI to RCA cable or do I need a converter also?
    President:
  • 2,559 Answers
Before connecting the external monitor,Shut down your computer,connect the external monitor,Restart the computer and the external monitor should load and The FN+F8 should now work.
Posted on May 21, 2009
    Problem Solver:
  • 16 Answers
If you right click on the desktop and choose properties, this should bring up Display Properties. The settings tab should give you the option to change your video output device to TV.
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
How to connect a laptop to tv
The laptop has an additional connection for some type of external display. The connection will be a VGA Port, S-Video Port or an HDMI Port. The tv will need the same type of port as the laptop so that you can connect a cable between the two of them. If the connections are not the same, you will need some type of converter that will go between them to make them think they are the same.
Once you connect the two with a cable, take the tv's remote and press Select Input, then select the Input Source where the tv is to receive the signal (PC, S-Video, HDMI). Reboot the laptop and the video should appear on the tv.
Jun 01, 2012 | Computers & Internet
How to connect my dell latitude laptop to my symphonic tv via s-video cable
Run the S-Video cable from the laptop to the tv. Take the tv's remote control and hit the Select Input button. Select S-Video or PC as your input source. Reboot the laptop and the video might show automatically.
May 23, 2012 | Dell Latitude D610 Laptop Computer -...
How to connect a toshiba m50 to a toshiba regza hd tv
They both have to have the same type of connection such as VGA or HDMI or connect a cable between them otherwise you will need some type of interface between them to make the connection.
Once you have the cables connected, get the tv remote and press Select Input to tell it where the signal is coming from (PC, VGA, HDMI). Reboot the laptop and the image will appear on the tv.
May 21, 2012 | Toshiba Satellite M50 Notebook
Can,t connect to tv with hdmi cables
Why not? Did you take the remote to the TV and click Select Input, then select HDMI?
Did you reboot the computer after you connected the cables and selected hdmi on the tv?
May 17, 2012 | Computers & Internet
Connecting Eee pc laptop using xp to my tv with vga
Connect the VGA cable to the laptop and to the tv. On the TV take your remote and go to Select Input then select (PC or Computer or VGA just depends on your TV). if the image is not on your tv, reboot the laptop.
After rebooting if the image is not on the tv, try the steps below.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) located at the lower left portion of the keyboard + the correct F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 09, 2012 | Acer Aspire One AOD150-1165 Notebook
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Connecting latitude D630 to Sony Bravia
Disconnect all cables and reboot your computer.
Turn off your hdmi TV as well.
When computer is already on, connect the VGA/HDMI cable to your computer and the other end to the TV.
Turn TV on then press Fn+F8 ONLY ONCE.
May 25, 2010 | Dell Latitude D630 Intel Core 2 Duo T7250...
My LCT 2662 (AKAI) will not recognize my laptop via a VGA
Update the video drivers on your laptops. Reboot both devices.
Dec 15, 2008 | Akai LCT2662 Television
Compaq nx6110
Usually one of the function buttons F5-F8 etc together with the FN button will toggle through from lcd to tv/external monitor to both.
Is the cable S-Video or does your tv accept a dvi or vga input?
Do you connect using the s-video output on the laptop or the standard external monitor port?
Mar 21, 2008 | HP Compaq nx6110 PC Laptop
Dell InspironTM 1501 Notebook Logo
541 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
