Sense of self - Computers & Internet
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
F82 error
door switch not sensing properly or a bad power relay board.
Oct 01, 2012 | Thermador Ovens
Will the regular use of an electric massage chair help me in any way on an emotional level or just physically and mentally?
There are many ways in which massage chairs can help users emotionally. Some include a feeling of well-being, reduced levels of anxiety and nervous tension, an enhanced self-image and self-worth and a sense of having harmony within.
Aug 06, 2012 | Furniture
Toro self-propelled lawn mower: throttle doesn't work, I suspect I may have mis-connected the spring and rod connecting the swivel plate to the lever arm. Does that make sense to anyone?
Yes it makes sense. I was working on a throttleless one and it would not come up to speed, I had hooked it up to the wrong side of the shaft, or conceptually, the pivot point. It was doing the opposite of what it should have. I suggest taking a really close look at the attachment piece looking for wear or rub marks to indicate which hole it should be in.
I hope this gets you going.
Aug 09, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have ford explorer 2002 ...and the mecaninc said apear code P1780 and P1733 what means
P 1780 = neutral safety switch
P1733= 4C Pressure Switch Sense Circuit
Looks like you have transmission problems
Feb 04, 2011 | Ford Explorer Sport Trac Cars & Trucks
THE PRINT FROM MY LEXMARK PRINTER IS SMALL AND I CANNOT ADJUST THIS. CAN YOU HELP PLEASE
Your printer supports a wide variety of paper sizes. See Media guidelines for illustrations of proper paper orientation. The printer determines the size paper loaded in the trays by the position of the paper guides. Make sure you adjust the guides each time you change paper sizesYour printer can automatically sense when A4, letter, legal, executive media or B5, DL, and #10 envelopes are loaded in tray1. To do this, the Auto Size Sense setting must be set to On. Your printer default was set at the factory to either the US or Non-US default with the Auto Size Sense setting On.To change the Auto Size Sense setting to Off: 1 Turn the printer off. 2 Press and hold the Go and Stop buttons and turn the printer on. 3 Release both buttons when Performing Self Test appears. 4 Press Menu> or <Menu, until the Tray 1 Auto Size message appears. 5 Press Select. 6 Press Menu> or <Menu, until Off appears on the display. 7 Press Select. To return the Auto Size Sense setting to On, repeat steps 1 through 7 but, select On during step 6.
Sep 03, 2009 | Lexmark P4350 All-In-One InkJet Printer
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Troy bilt self propelled problem
My only guess is you've put the cable actuator in upside down. Sorry, that's the only thing that makes any sense.
Aug 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How does self cleaning work on my frigidaire gas burner stove?
Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
Nov 28, 2008 | Ovens
Whirlpool self cleaning oven
the door stayes locked untill the oven senses its safe enough to open can take up to 1hour after cleaning if not unlocek by that time start cleaning again then hit cancel
Dec 29, 2007 | Ovens
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
