Question about Samsung TV Remote Control
Can't change channels. don't have remote. need to get channel 3 for cable
I don't have my philips remote control and i cannot manually change channels
  • cathy3275 May 21, 2009
    this is everything I already know how to do. The buttons are not changing the channel on the TV. Going to buy a universal remote tomorrow.
  • 65 Answers
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
Posted on May 21, 2009
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
No remote tv stuck in cable mode no channel 3
See if you can get a manual for the set at web site or try a google search.
Sep 07, 2017 | Televison & Video
Need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jun 17, 2009 | RCA Universal Remote Control
I need the code to program the philips universal remote to a sylvania tv
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Need codes for philips remote control SRU4208WM/17
the process is similar
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Programing
Hope this helps :)
Jun 09, 2008 | Philips Universal PH301S Remote Control
Philips remote codes
Hope this helps :)
May 25, 2008 | Televison & Video
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Samsung TV Remote Control Logo
399 people viewed this question
Jerry Greenberg
Jerry Greenberg
