Question about Samsung DV219AE Dryer
When I tried to rotate tumbler, heard loud band. Now dryer will not work
Move tumbler and heard loud bang. Will not work now
2 Suggested Answers
  • 30 Answers
SOURCE: Samsung 60 plasma T.V. made a loud bang and wont turn on now.
This is common on Samsung Plasma TV's
Give us a call we can walk you through finding the needed part numbers for your replacement board.
909-598-9777
Thank You,
TvPartsGuy.com
http://www.tvpartsguy.com
Posted on Jun 24, 2015
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
My whirlpool duet sport dryer made a loud bang then stopped working and now says its sensing,,what could be wrong
Try reaching inside the dryer and turn the drum by hand. There should be some resistance because of the belt going around the drum. If you can turn it freely my guess would be the bang you heard was the belt breaking and the idler pulley hitting the floor or the side of the dryer. Most dryers today will not run if the belt breaks because of a safety switch. Hope this helps.
Jul 23, 2014 | Whirlpool Dryers
Rotated drum by hand heard loud bang
take off top see if counter weight came loose
Mar 01, 2014 | Haier RDE350AW Dryer
My Hotpoint tl61p tumble dryer made a loud bang, and now will not work, the timer justs buzz's? can anyone help please?
The load bang you heard was the idler pulley slamming into the frame more than likely. this is because your belt broke removing the tension suddenly. Put a new belt on and you'll be fine.
May 08, 2012 | Hotpoint Dryers
Hi i went into my dryer and pushed the tumbler the wrong way and heard something pop and now the tumbler doesnt rotate how do i get to the belt this dryer is very old but looks like this one .thank you oh...
You broke the belt. To replace it, pop the top ... use a screw driver. Remove the screws at the top of the front, remove the front, the drum will fall free. Take Pictures.
Feb 14, 2011 | Kenmore 65924 Electric Dryer
Eaton viking dryer model ED214W449 .Loud hum when you try to star
My Eaton Viking Dryer Model # ED214W449 was running, I heard a loud bang and realized the drum had stopped turning and won't restart. Is this a drum belt issue? Is it hard to repair myself. Where can I get the part for this. Thank you.
Mar 24, 2009 | Dryers
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Samsung DV219AE Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
