Question about Acer H243H Monitor
Monitor Goes Black
After the ACER logo comes up and it goes to the computer for about 3 seconds and then goes black ?
SOURCE: Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Posted on Jan 12, 2008
SOURCE: monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Posted on Dec 29, 2008
  • 86 Answers
SOURCE: al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Posted on Aug 11, 2009
budmrtn
  • 11361 Answers
SOURCE: My monitor comes on for
I t can be power supply problem, backlight inverter circuits, CCFL assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6147800-basic_guide_applied_most_lcd_monitors
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 27, 2010
SOURCE: monitor comes displays Acer logo and goes black
monitor comes displays Acer logo and goes black after 1 seconds, with indicator light still green.
Posted on Oct 22, 2010
Acer X193W Monitor comes on correctly, but after about 3 seconds it goes black. Can turn off & back on & get the same result.
the problem is not with your monitor the problem with your cpu which is not providing the signal that's why it goes off
Mar 04, 2013 | Acer X193W LCD Monitor
Monitor comes displays Acer logo and goes black after 3 seconds, with indicator light still green.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Acer al2416w acer logo comes up then light goes yellow and no signal detected shows for about 20 seconds then black screen only
Try opening it up, and reconnect the connectors on the three different boards. Worked for me for a while.
Oct 14, 2010 | Acer AL2416WBSD 24" Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer H243H Monitor Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
