Question about Electrolux Central Vacuum
Central Vacuum system doesn't turn on
The air is flowing, but the part that rotates won't turn on
Vacuum runs for awhile and then shuts off
This sounds like an overheat issue. I suspect that something has restricted the air flow. Air flow is required for function and to cool the motor. if the air flow is restricted a thermal limiter opens the circuit, rather than have a fire.
Mar 04, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush will not turn
brush will not rotate... should I ASSUME it is an upright? IF SO, I assume that it has a drive belt. I guess that you have removed the 3 or 4 screws that hold the belt cover in place and have confirmed that te belt is not broken. Note that excessive hair in the belt drive area can prevent the brush from turning. If you have an air pressure drive system (rare), then hair can clog the air flow to the drive impeller. You provide no information that can guide me to give specific trouble shooting suggestions.....or solutions
Jan 13, 2012 | Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Brush wont turn belt not broken no sure how to get to shaft to see if it is turning
Sorry to hear you're having difficulties with your DC07. If the brushbar in your cleaner doesn't seem to be rotating, please check you have the brush control set to 'Carpets', as it won't rotate when set to 'Hard floors', or if the cleaner is standing in the upright position.
If the brush control is set correctly and the brushbar still won't turn, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes will not turn even though I have the switch on for the brushes
When you move the swwitch to on, you are moving a baffle to allow air flow into the turbine to rotate the brushes. try to move them by hand with the machine off. if you cannot the turbine nees service. if you can check the tank lid is on, foam filter for dirt.
Sep 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not turning
If your brushes are rotated by a black rubber belt, chances are that they belt has stretched out or has been worn and you need to replace that belt, also , check and remove any black rubber residue from the brushes and where the belt loops around. Also check for obstructions thru the hoses restricting air flow.
Aug 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
55 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
