Question about Panasonic PanaFax UF-8000 Laser Fax
What is printer error E01-22
I receive a contact your dealer printer error E01-22. What does this mean?
    President:
  • 3,085 Answers
You have a bad LASER unit.
Posted on Jun 04, 2009
I have an error message: E161-403E
It means " abnormal print head temperature"
You need the print head exchanged.
Contact you printer dealer.
Mar 10, 2011 | Canon imagePROGRAF IPF710 Printer
Receiving error 52.00 error. What does that mean?
Here is what HP says:
52.XY ERROR For help press c00244025.gif alternates with To continue turn off then on Description A temporary printing error occurred. Action
  1. Turn the printer power off and then on.
  2. If the message persists, contact an HP-authorized service or support provider.
Jan 07, 2011 | HP LaserJet 2420 Printer
Receiving printer error code 5020..wht does it mean and how is it corrected?
The error indicates either an unseated encoder strip or a faulty black or color cartridge. Please refer to this article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the troubleshooting steps in the article, please contact Lexmark technical support for additional help. Thanks.
Dec 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
Hp lj p3005dn problem error 51.10
Hello, The 51.10 error in the HPP3005 indicates a general fault. A power cycle will usually clear this error. The error itself is undetermined and information of what it means is seemingly unavailable.
I would suspect this may relate to the laser scanner or a laser beam detect issue, based on previous printers error faults.
If the error persists, contact your local HP Dealer for repair.
I hope this has been of assistance.
HPPARTNERLOCATOR
Dec 02, 2010 | HP LaserJet P3005 Printer
Receiving an error 234 jam on the Lexmark E360d printer but there is no paper jam. I have turned off the printer and it still will not work. Please advise asap.
You may be having a problem with your paper sensors. If your printer is covered under warranty contact Lexmark and have the issue covered under warranty. If not you may need to contact your local Lexmark dealer.
Jun 07, 2010 | Lexmark E360d Laser Printer
116-330
Enter UI Diagnostic(hold 0-zero for 6 seconds and press Start button, find Diagnostic) in dC355 Hard Disk Diag Program and make a diagnostics of HDD. Refer to Initialize Hard Disk procedure in UI diagnostic <!-- from fixya rte -->
May 21, 2010 | Xerox DocuColor 12 Printer
Have a 2004 GTO with the following error: Fuel Guage Error - Contact Dealer Service Error - Contact Dealer Air Bag Fault - Contact Dealer Any idea how to fix this?
If these are false readings (which I doubt) you can try resetting the system to restore all factory default settings. You need to have the system set in customisation mode to do this.
Check your vehicle handbook which explains the steps to do this.
Once reset drive the car and check the warnings.. If they remain (and they probably will) you will need to take the car to the dealer to diagnose and rectify the problem.
Your handbook explains what each of the warnings means and the air bag fault warning should not be ignored. "Service error" means there is a fault with the instrument panel and Fuel Gauge Error means there is a fault with the fuel level measurement system
Oct 20, 2009 | 2004 Pontiac GTO
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
ERROR CODE - 1600
1600 MEANS THE CONTACT NUMBER OF THE DEALER...LOOK THE SC WHAT THE NEXT NUMBER INDICATE.
May 19, 2008 | Ricoh Aficio 450 Copier
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
241 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
