Question about LG 55LX6500 3D TV
Update firmware usb lcd - LG 55LX6500 3D TV
My sony bravia KDL-55HX800 SWITCHES OFF ITSELF
It appears to be a normal issue with this model, however there is an update on Sony's site that addresses that issue. If you look at the very bottom of the update details I'm about to post, you will see it
55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
Click on Firmware and Read towards bottom of File Description.
The firmware update can be downloaded here
This is how to update by using a USB Storage Device
System Software Update 55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
May 23, 2014 | Sony BRAVIA Televison & Video
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
How to update firmware on Sanyo DP52848 ? There
If you wish to get more details about firmware update, check this link. It has firmware update procedure to many model TVs, with illustrations. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Sanyo DP52848 52 LCD TV
Update firmware usb
I believe the correct model number is LN40A550. If so here is
the download firmware page for it..
http://www.samsung.com/us/support/owners/product/LN40A550P3FXZA
Aug 24, 2013 | Samsung LA40A550 40 in. HD-Ready LCD TV
Needs software update how do i update this tv
Does the Tv have a USB port? If so you should be able to find the firmware on the makers website, assuming the company made a firmware update for that model. If so then download it to a flash drive, zip drive and plug it in to the TV's usb port for the update! Best of Luck!
Apr 10, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
Stuck in safe mode
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration.
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration.
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
I have a sony lcd and i want to update it
No, Brother.
Sony LCD will only accept "Sony Micro Vault"
So try using sony Data Treveller.
KIndly Do Rate, If helpful.
Jul 17, 2009 | Sony KDL-32S3000 32 in. LCD Television
Broken tv
I had problems with channels on my Olevia LCD TV. My problem was solved by updating to the latest firmware.
http://www.olevia.com/en-us/Support/Firmware.aspx
Make sure the USB flash drive is formatted with the right file system, or the set will not see the updated firmware.
Mar 30, 2008 | Olevia LT26HVX 26 in. LCD Television
LG 55LX6500 3D TV Logo
29 people viewed this question
Computer Repairing
Computer Repairing
