Question about Saeco Incanto Classic Espresso Machine
Beans wont fed int grinder, it grinds a long time, stops and light comes on
espressodoc
  • 29 Answers
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Posted on Jul 27, 2007
SOURCE: Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Posted on Aug 08, 2007
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
SOURCE: Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Posted on Nov 24, 2009
  • 352 Answers
SOURCE: the grinder runs but does not grind the coffee
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
Oct 21, 2009 | Gaggia Paros Espresso Machine
Our Saeco Delux Magic coffee maker will not grind the coffee when we push the button. A light comes on that indicates that the grinder could be jammed.
Hi
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
13 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
