Question about Saeco VIA Venezia
IT WONT CONTINUE TO PRODUCE STEAM FOR MORE THAN THIRTY SECONDS
Wont produce steam.Sole plate is hot and water is being heated but no steam being produced.18 months old,cleaned after every use.
Pour some vinegar in it and let it set for several hours cold. Then warm it up. This should start to dissolve the leftover minerals blocking the steam holes. May take several attempts, but it will eventually start to steam again.
Aug 08, 2015 | Irons
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Maax steam shower
To get replacement parts for Maax steam shower, you can prefer showerenclosures.
Nov 13, 2011 | Home
My pump at the base wont go up and down to produce steam. Any suggestions?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 04, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Have used 3 times---wont produce any steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
q
Sep 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Doesn't produce steam for more than 1 minute.
You should not have your steam wand on for more than a minute.
Jun 29, 2009 | Gaggia Carezza Espresso Machine
Turns on but won't produce steam
heatman101
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Saeco VIA Venezia Logo
19 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
