Question about Vtech V.Smile TV Learning System
How to put batteries in
Took screws out how to open and place batteries in
Replace the battery in my onboard jump pack mine will not hold a charge
No Photo No Model No Brand listed in inquiry.
Basically you keep the jumper cables separated because these packs can hold large amounts of electrical power. Bagging them and taping them is effective. Duct tape works.
Remove screws and dont lose them. The case or shell opens like a clam shell. Be careful because some parts or circuit boards may not be screwed down and come out of their slots when its opened.
You will find one of several batteries inside.
There is a 7 amp hour to about 20 amp hour battery inside depending on how big and how high quality the jump box is. Remove the battery
Find a battery supply place like our Meridith Battery in Cranberry 16066 or Batteries Plus near 15234 and take your old battery with you... you will need it to trade in.
The car parts stores dont have these. Battery supply places, Granger, Interstate, and other full service battery facilities will carry these.
PowerSonic, Yuasa, Panasonic, CSB, Deka, Rocket, Exide, Johnson Controls are all main line brands in this catagory of battery.
Newark Electronics, Granger, and Ebay all have these as standard fair. This is not a walmart advance autozone napa item.
Install in the same manor you took it apart being very very careful not to short anything or put anything in the wrong spot. Charge 24 hours before use.
DONE
Feb 17, 2015 | Vehicle Parts & Accessories
I am trying to replace the battery cover for my EasyShare cx7330. I have received the replacement cover from US Camera. Can I move the left-hand retaining piece by unscrewing the screw that is located...
I think you should remove all screws around the camera, to move the underside like 1/10 of an inch or less. Don't forget to lift the side of the battery door, on the side you opened the camera. First place the pin on the other side of where the camera is open and then move the door in its place. Than close the camera and put in the screws. ready
Jan 26, 2014 | Cameras
CMOS battery gateway t-1625
Remove the keyboard and the media button panel.
Remove all the screws from the underside of the laptop.
Remove the access panels.
Remove the hard drive.
There are three screws that holds the chassis together here (inside the hard drive bay). You won't be able to completely open the chassis but now you can use a flat blade (I used a small flat head screw driver) and pry the top and bottom pieces apart.
As I mentioned, you won't be able to completely take the two chassis pieces apart but you will now have enough clearance to access the CMOS battery to the right of the headphone jack (looking at the bottom).
I used a small flat head to pop the battery out. I then used long tweezers to place the new 1220 battery on the battery tray and reached around from the hard drive bay and popped it in with my index finger.
Put everything back together in the order you took it apart.
Apr 05, 2012 | Gateway T-1625 Notebook
Took off back brakes to replace pad. Need help
use a flat tip screw driver put flat edge on pin where spring hooks up put spring on brake pad the hook onto screw driver lift up as lifting spring will slide along screwdriver and into place .
Apr 16, 2010 | 1991 Nissan Maxima
I got my Palm Centro wet. I took the screws out
do not put your phone in ANY liquid, even rubbing alcohol! any liquid puts your phone at risk of corrosion in places you cannot see. even if it works fine now, that is no guarantee that there is not still small amounts of moisture inside that may still cause damage later. take your phone apart, put all the pieces of your phone in a ziploc bag of uncooked rice, and LEAVE IT IN THERE for at least 24 hours. having the battery in at all when there may be moisture inside puts your phone at risk for more damage. save yourself trouble later by leaving it alone in the rice for as long as you can. two days would be better.
Jun 26, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Replacing battery onTI-30xa
I have the battery powered TI-30xa and I didnt press anything when I was done.
I:
1) opened the back by taking out the screws
2) took out the old batteries
3) put in the new batteries
4) closed the case and put the screws back in
5) it has worked great since.
Mar 25, 2009 | Texas Instruments TI-30XA Calculator
Computer novice--hasbro battery
Once you backout the retaining screw, put your fingers in the gap between the battery compartment and the switch. Push the battery compartment to the rear of the pony then you can remove it.
Jan 15, 2009 | Hasbro Fur Real Friends Smores Pony
Cant get it back together
I put together what I knew where it went, the put the whole thing together and looked at it before putting in the screws. I saw a hole and remembered a "button" there that moved sideways with a spring pushing it back into the original place. I reopened and after examining the part put it in that slot. I then put it together and it worked. I put the screws back in then and all is well
Thank you for the reply.
Glad I found your site. I will keep it if I ever need any help.
Kathryn
Oct 11, 2008 | HP Wireless Optical Mouse
ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
Aug 11, 2008 | Estro Barista Athena
HELP!
dunk the phone in metholated spirits (it is alchole which will eveporate and evaporate the water) a few times and the put ur hair dryer on cold and dry it. now because water and electricity dont like to meet you have shorted your battery which means you will have to charge ur battery for a while before your fone will operate then use ur sxc water fixed phone
Apr 09, 2006 | Nextel i730
Vtech V.Smile TV Learning System Logo
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
