Question about Gateway GT4024 PC Desktop
I'm trying to fix a gateway MFATXNIN NMZ 500SE
No power even @ test switch. Any answers???? I'm not too keen on Gateway, but it looks to me they only want Gateway people on it. Even opening it is a pain in the ***...
David  on button lights up and small light on mother board thats all it does nothing tried test switch nothing happens
  • Jeff Strader
    Jeff Strader May 11, 2010
    o you have a test power suppy you can sub in , that's probably the cultpret. :)
  • 527 Answers
Sir,
  1. Press and hold the power button down for 10 seconds.
  2. Make sure that the power and hard disk light-emitting diodes (LEDs) are on.
  3. Check the power cable connections:
    • From the electrical outlet to the AC adapter.
    • If applicable, make sure the LED on the AC Adapter lights.
    • From the AC adapter to the notebook.
    • Make sure that the power strip is on.
    • Make sure that the surge protector is on.
  4. Try another electrical outlet.
  5. Disconnect any external devices, like PC cards, digital cameras, or external drives.
  6. Disconnect the notebook from the docking station (if applicable). Remove any power strips and surge protectors. Plug the power cord directly from the notebook into the electrical outlet.
  7. Remove the battery and reinstall the battery. Refer to the documentation that came with the notebook.
  8. Remove any newly installed software or hardware.
  9. Remove any additional memory. Refer to the documentation that came with the notebook for memory removal instructions.
  10. Shut down the computer, and then remove the drives. Refer to the documentation that came with the notebook.
  11. Push the hardware reset (if applicable). Refer to the documentation that came with the notebook.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 21, 2009
Gateway nmz500se Ethernet card does not work
did you installed the driver. go to my computer right click choose properties then go to device manager and see if ethernet it ok or it have a yellow ?.
Apr 09, 2013 | Gateway NMZ-500SE Notebook
Need manual for gateway mfatxnin, nmz-rw 1800c
http://support.gateway.com/support/manlib/Desktops/desktop.shtml i found it on here but it wont let me link directly to your model
May 14, 2011 | Computers & Internet
BIOS upgrade for a Gateway
You can't. G/W models below 310 are not supported any longer.
Gateway sold out a bunch of support
Jun 25, 2010 | Gateway 300 C PC Desktop
Gateway mfatxnin nmz 300s no power opened power supply box lloking for a blown fuse or something?
sometimes they just die the windings burn out in hidden spots and trust me i took 1 apart to find the burn it's not worth the time just to have a look
spend the cash and buy a universal adapter
just rember voltage and amp or mily amps required
Jul 23, 2009 | Computers & Internet
RAM upgrade for Gateway model MFATXNIN NMZ 300L?
The system takes PC133 SDRAM, as far as i know without performing a BIOS flash it can take up to 1GB (2x512MB) most of these PC's are restricted to 2x256 so a BIOS flash could be imminent in this case.
Good luck
Jun 19, 2009 | Gateway 300 C PC Desktop
Gateway E-Series Machine
look for any screws in the back near a side panel(usually the right side). loosen them all!
then, look for any sort of button in the back to push down on. push it down while pulling backwards on the case panel.
I hope this helps!
Jun 11, 2009 | Gateway NMZ-500SE Notebook
HOW DO YOU REMOVE THE COVER FORM A Gateway PC Model # MFATXNIN NMZ 300X CEL?
There should be a front release just below the Gateway logo. Press this and it will release the cover.
Apr 16, 2009 | Computers & Internet
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Laser mouse light won't come on when is used to
If you have a USB mouse, try it on a friends PC or laptop.
if it works there then check your USB (Universal Serial Bus Controllers) in the Device Manager...
right click My Computer
select Manage
select Device Manager
from here you can check you "Mice and other pointing devices, and your USB controllers
Good Luck!
Gateway GT4024 PC Desktop Logo
433 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
