Sherwood dvs46 How to connect set top box to tv
2 Suggested Answers
jmeredith
  • 417 Answers
SOURCE: How do I connect to
Your set top box should have secondary RCA outputs along with the HDMI. run another RCA standard yellow- red- white cable to the Onkyo's video 1 input. Use Monster cables for best performance..
jm
Posted on Mar 20, 2011
I have a zenith 5 device universal remote can i program it to opporate my RD-7500 Sherwood receiver. don't have original remote, what code can i try?
0374
This is the only one code, that I can find out to Sherwood TV. Anyway there might be more. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Irrespective of the brand name of the remote control, some other codes said for Sherwood TV might work.
Sep 27, 2015 | Zenith Televison & Video
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
I cannot seem to get the tv audio going through the amp, i have connected the red and white audio leads from the tv to monitor out, I've also tried connecting it through cd but to no avail. the audio...
You can't get ANY audio to work on receiver's Monitor Out (which is a component video OUTPUT intended for your TV, not an audio input from it).
Read the manual and get a handle on what those 3 jacks are for (page 6).
http://www.retrevo.com/support/Sherwood-RD-7502-Receivers-manual/id/2536ag207/t/2/
Then, if you really need audio from the TV (instead of or in addtion to the probable Cable/SAT Box that originates TV-related programming), just run the audio out from the TV to any available Line Level audio input. The Cable/SAT box is the BEST place for the BEST TV-related audio and it will be available digitally.
The TV's audio control plays a part in this, too. Find its menu and select a FIXED (or equivalent) setting so you can turn the cruddy TV speakers down without killing the audio output.
Sep 07, 2011 | Sherwood RD-7502
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
I have a RD-6108 5.1 Channels receiver that want to connect to my flat tv. Can you help me?
If you consider that a TV is just a lightshow, it's not that complicated...
Composite Video Out to composite video IN on the TV would be the minimalist absolute necessary connection for managing the receiver through On Screen Displays.
Unless you intend to dub video to a VCR or something, there is no reason to bring TV video into the receiver.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RD-6108-Receivers-manual/id/516ci958/t/2/
My preference is to send the BEST version of any medium (audio or video) directly from it's original source to the BEST ELECTRONICS that uses it; then send minimalist versions across for convenience and lo-fi watching/listening.
Any self-respecting modern TV has multiple hi-def video inputs, so run the Bluray, DVD, cable box video straight in and run the audio from those devices to the Sherwood.
Fewer expensive cables, no excessive connections to go bad, no unnecessary handling of the material.
I'm pleased to see the manual for this one (and the product's limited video capabilities) don't tempt the user to route everything through it on the way to the TV.
Feb 23, 2011 | Sherwood RD-6108 Receiver
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
22 people viewed this question
 Grubhead
Grubhead
