My washer keeps flashing f21 and no matter what I do it doesn't seem to work.
    Sergeant:
  • 187 Answers
Hi
f21 is long drain, failed to drain in 8 mins.If unit did actually successfully drain normally then pressure sw is likely the problem.
1. did pump come on? if no replace pump
2. is unit draining at normal rate? no then clean pump.
if yes on both replace pressure sw.
to second poster if getting suds error when using HE then you likely are using to much detergent. If avail run a clean washer cycle.
or normal cycle with bleach or fabric softner, no clothes..
please rate my suggestion..
Posted on May 21, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
Aug 31, 2011 | Washing Machines
I have cleaned out the washer and cleaned the filter for the f21 code .i tried to restart washer with nothing in it and it washed for a minute the stopped and flashed 5d again what can i do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is not spinning or draining it keeps flashing F21
Hi
Daniel
Aug 24, 2011 | Kenmore HE2 Plus Front Load Washer
What is an F21 flashing? My washer will not turn off or anything. It is humming and flashing F21. Thanks
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
F21 is flashing
This means the water is not draining out like it should. I solved this problem initially on my washer (my drain pipe was clogged), but now (about 4 months later), I have a flashing F21 and 5d, because of a clog some- where. I can drain and rinse (after this cycle, the door will unlock), and the tub spins, but I can't complete a cycle. Lots of debris has come out with rinse water, but I still seem to have a clog somewhere. I can complete a wash load by manually switching the settings.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The F21 signal keeps flashing.
f21 is long drain, failed to drain in 8 mins. f27 is overfill, overfill contacts on pressure sw closed. If unit did actually successfully drain normally then pressure sw is likely the problem.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
