Question about GE Energy Star WCVH6260F Front Load Washer
My washing machine suddenly stoped working today and it is giving me LE sign on my display.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
The first thing to do with any electronic controlled product is to unplug it for a few minutes and then plug it back in..Good Luck
Posted on May 21, 2009
My machine cannot spin and drain water, it keepson displaying the LE sign which I have investigated to be unclosed lid signal. So how do I fix this problem
If the lid is closed and an LE error is displayed, the lid switch may be defective and will have to be replaced.
May 04, 2016 | Washing Machines
Washing machine Lg 7kg WD 1256 problem LE sign direct drive the cylindre move difficult and stop
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jul 10, 2011 | LG WM2487H Front Load Washer
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
LE sign comes on
over suddsing is what this erro indicates. Clean the pump out as well as the hoses and use less soap.
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG WM-2277HW Front Load Washer
Not running giving a beeping noise and a LE sign
if that unit is a direct drive then le code is motor senor or motor fault. change sensor first.when i found this problem at customers machine 90 to 98% it was sensor. please reply 4 more help
Apr 09, 2010 | LG WM1814CW Front Load Washer
Machine stopes and reads le
Here is a tip that explains that problem...
LG Washing Machine LE Error Code or Fault Code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Mar 27, 2010 | LG WM-2277HW Front Load Washer
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
LE fault code for LG WD-1019bd washer
Usually it is the stator at fault with an LE error. I would make sure the cable between the stators windings and hall sensor are ok back to the main control board also give the wires a good tug sometimes the copper breaks inside the wiring insulation at the white connection blocks. Check to make sure theres nothing got trapped inbetween the drum and tub this can lock the drum up and give the fault. After checking all the above i would think it would either be a faulty stator or the main control board has failed. Hope this helps.
Dec 21, 2008 | Washing Machines
Receiving an le display.
you more than likely have a bad RPS sensor, dont know if i would want to mess with that, you could wind up damaging the motor/rotor in process of getting to
Dec 06, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
129 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
