Question about Chicco My First Car Rattle
2011 chevy colorado rattles when going over bump
Sounds like a metal rod hitting somewhere
My 93 chevy cavalier sounds like metal is hitting when i start it it and when im driving
Knocking sound. Rod bearings. More of a rattle sound, check the heat shields on the exhaust system.
Sep 10, 2016 | 1993 Chevrolet Cavalier
Why do truck makes rattling noise when hit bumps?
I would Have a Professional Look @ it, there are 25 different parts there that could Either Be Broken , or ready to Break.Tie Rod ends, Stabilizer Links , ECT.
Jul 26, 2014 | 2003 Ford Ranger Regular Cab
My 95 deville rattles a lot when I hit bumps ,,,what could it be
I would start with checking the muffler and pipes to see if they move when u push on them. Make sure car has set for a while so u don't get burned
Apr 07, 2014 | 1995 Cadillac DeVille
Rattling like metal to metal in rear of car when i hit bumps in2003 envoy
Most likely are the sway bar end links have gone bad, these fail quit e often.
Sep 27, 2012 | 2003 GMC Envoy
Rattle noise in the trunk area
Spare wheel?? Jack kit?? Exhaust heat shield?? Brake pads rattling in calipers?? Try pressing the brake whilst goin over the bump, then handbrake (slowly)
Aug 12, 2012 | 2002 Jaguar S-Type
I have a 1997 Jeep Grand Cherokee, Im getting a rattle under the jeep. It sounds like metal hitting metal its not the exhaust for that is not hittig anything. it sounds like its to the rear. Someone said...
Your jeep has two upper and two lower control arms attached to the rear axle. They have rubber bushings where they bolt to the axle and to the body. If the bushings are badly deteriorated, you will get a metal to metal sound when hitting bumps. Have them all checked.
Jan 03, 2011 | 1997 Jeep Grand Cherokee
Why does my 2005 Chevy Colorado have a rattling sound when I run over any bumps?
Could be a number of things. Best advice is to take it to repair place with a hoist, get it up in the air and have them check out the exhaust system (might be a broken strap or mount), shocks, etc... could be the brake pads...and on and on.. Problems like this are USUALLY minor fixes but I would recommend getting it to the shop soon (before something falls off..).
Good Luck
Dec 13, 2009 | 2005 Chevrolet Colorado
I hear a chirping noise coming from somewhere under my truck when i go over bumps. where is the best place to start looking for that?
With the engine off you could try hitting around on your exhaust system to see if it is touching any place also check your suspension system for metal contacting a unprotected area.hope this helps
Sep 24, 2009 | 2006 Chevrolet Colorado
Front Right Tire Making Bad Rattleing Sound
Chrysler products as a whole are not well known for quality front end components ( I own one ) I would check the upper and lower ball joints and tie rod ends for worn or damaged parts. If no satisfaction here consider returning to where it was repaired and have them re-inspect thier work. All of us in the industry do are best but none are perfect.
Nov 04, 2008 | 2000 Jeep Grand Cherokee
Chicco My First Car Rattle Logo
78 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
thegtw
Shehu Pro
Shehu Pro
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
