Question about Avanti Compact Thermoelectric Refrigerator
Will not keep cooling shuts off
My avanti compac refridgerator starts up but shuts off after a few min. and will not cool but when i leave the door open it gets ice on the freezer
  • marlonhyd May 22, 2009
    Thanks Sea Breeze For Confirming My Thoughts On The Problem marlonhyd
  • Avanti Master
  • 4,655 Answers
Sounds like a your problem may be in the thermostat. Reason I say that is because when you leave the door open it continues to run and freeze and frost is seen on the freezer walls. I just think maybe the thermostat has become less sensitive to temperature change. To test this unplug the freezer and connect the 2 wires to the temp control together. Then the refrigerator will run continuous until unplugged. Let me know, Sea Breeze
Posted on May 21, 2009
  • John Tripp
    John Tripp May 22, 2009
    You Are Welcome!
How do i shut off rfg298aabp freezer, but leave refridgerator on ?
The freezer cools the fridge via a flapper door, so one needs the other.
Mar 22, 2018 | Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
LG Refridgerator LFC257060ST Keeps Beeping
Please check whether the doors are aliened properly to the body and if there is a small warp it could result in escaping of cooling resulting in poor cooling of both the freezer and the refrigerator chamber.
The magnetic gasket is the next reason for poor cooling. So please ensure that the gaskets are having magnet attached to the full length. Broken magnetic strip inside the gasket could also result in partial closing of the door leaving behind plenty of gap allowing the cooling to escape.
Just insert a visiting card between the gasket and the body and if you could do so then the gasket is not effective and requires replacement.
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
May 24, 2009 | Avanti Compact Thermoelectric Refrigerator
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Avanti Refridgerator
Does it have a fan and is it running.
Dec 13, 2007 | Avanti EC15W-2 Compact Refrigerator
Refrigerator Problem
Could be the temp control is not registering temps correctly. If you leave is below 6 does everything warm up? The compressor should only run when it needs to, not all the time. In other words, if you put it on 4 will the food stay cool (about 38F)? A typical unit only runs a few minutes a day if the doors are not opened up all the time.
Feb 02, 2007 | Avanti 310SST Compact Refrigerator
Avanti Compact Thermoelectric Refrigerator Logo
377 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
