Question about Jura Capresso Impressa F9 Espresso Machine
When making coffee grinds are dry.no water from spouts
5 Suggested Answers
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
  • 60 Answers
SOURCE: All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
Posted on Oct 06, 2009
espressonist
  • 1711 Answers
SOURCE: when making cappucino coffee using
The problem
you describe it can occur if you don't perform the tablet cleaning as describe
in the user manual at page 30, (see link below).
http://www.capresso.com/pdf/inst_z5.pdf
The machine
changes the direction where the coffee will be delivered via a solenoid valve.
The coffee oils that remains inside this solenoid every time you make a coffee
they can dry out and after many coffees and if you don
Posted on Jan 09, 2011
  • 8 Answers
SOURCE: Jura-Capresso Impressa Z5 - left coffee spout is
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Posted on Oct 18, 2013
How to unclog coffee spouts?
I have a different machine, but it came with a needle like cleaner for those tiny holes in the cup that holds grinds. Also, if I grind the coffee too fine, there isn't enough pressure to push coffee out of both holes. Make a coarser grind to see if that solves the problem.
May 01, 2016 | Miele CVA4066 Built-In Whole Bean Coffee...
Water and coffee leaks out of spout on second cup
it sound like you have some blokage why don't you give it a service ferst also check if the coffee is to fine it may cos this problem
Mar 12, 2016 | Breville Coffee Makers & Espresso Machines
Water streams from panarello and coffee spouts when making a coffee
Some express coffee makers are "sensitive" to the type of coffee and the way you fiil them. What you describe happened to me when I use s coffee too fine grinded and too compacted
Jul 29, 2015 | Saeco Incanto Classic Coffee Machine
Grinder grinds coffee, but does not make coffe and dumps dry grounfds
Hi your brew unit is blocked. Open the service door and remove the brew unit and wash and rinse under water. Hot is better. The spout on the back side of the brew unit canbe unscrewed and cleaned. This is where most blockages are, Dazza REPAIRER
Sep 25, 2011 | Saeco INCANTO DELUXE Espresso Machine
No water is pumping thru the water spout or the coffee spout, the machine is reading fine grounds and press okay for water. i've adjusted grinder dial and pressed water button but nothing happened
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Sep 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water comes from small spout below group when
Expansion valve, coffee grind might be too fine.
Nov 11, 2009 | EXPOBAR Office Lever
No coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
May 12, 2009 | Coffee Makers & Espresso Machines
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
No coffee comes out from the coffe machine
The grind may be too fine. The Brew unit is plugged and needs service. The spout joining the boiler to the brew unit is broken. The unit may be plugged with scale.
Jul 24, 2007 | Saeco Magic De Luxe Espresso Machine
Jura Capresso Impressa F9 Espresso Machine Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
