Onkyo troubleshooting my onkyo 7.1 receiver make a loud pop sound stopped working and will not power-up. the red power light is flashing.
  • 979 Answers
SOURCE: Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Posted on Oct 25, 2007
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
hi-fi
  • 25 Answers
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
Onkyo TX-SV515PRO2 -- circa 1994 When I turn it on sometimes there is no sound. I turn up the volume (sometimes loud) until this triggers the sound to suddenly work. Speakers work great.
Hello, I am sorry about your issue. It sounds like the receiver needs to be serviced. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo Audio Players & Recorders
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
Flashes 6 to 7 times
mine has done the exact same thing, and apparently ( have yet to try) there's a second fuse in the tv and that's the problem, now I need to locate the fuse!!! lol mines an older Philips, let me know if yours is the same problem
Sep 06, 2013 | Panasonic TC-P50G15 50 in. Plasma HDTV
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
I have the TX SR706 receiver for two years and yesterday when I turn it on it did a load boom sound and since then there are no sound
I had this happen to my unit shortly after I purchased it. When I turned the receiver on there was a loud pop through the speakers, the red light on the front started blinking and the unit failed to produce sound.
A tack worked its way through one of the speaker wires, causing a short. I replaced the wire and unplugged the receiver for an hour. It's worked well for the past two years since this issue.
If you haven't done so already, check all of your speaker wires and plugs on the receiver and the speakers. You may have a damaged wire or metal-on-metal contact somewhere. Try these steps:
1. Unplug the unit and disconnect all wires and connections. Let the unit sit for an hour.
2. Check all cords for damage or crossed connections.
3. Reconnect the power cord and set the volume to minimum. Turn the receiver on. If it stays on, shut it off, unplug it and reconnect everything, taking care to ensure that speaker wires and/or plugs don't make contact.
4. Plug the receiver in, set the volume to minimum (it should already have this setting after step 3) and turn it on.
It sounds like there is a short somewhere in either the wiring or the receiver. This caused the popping noise and activated the receiver's protection circuit. If it's a damaged wire or plugs or wires making contact, you can reset the unit with the directions above, replace or separate the wires and all should work. If the issue is within the unit, you'll have to contact Onkyo directly.
Dec 11, 2010 | Onkyo TX-SR706 Receiver
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
314 people viewed this question
 Grubhead
Grubhead
