Question about Solis Crema SL-70 Espresso Machine
Disassemble how do you open the machine
Can you give me instruction on how to disassemble the sewing machine?
Please provide useful information such as make and model number, and why you want to disassemble something you don't know how to disassemble in the first place.
Otherwise, I find these work quite well for disassembly:
Jan 28, 2018 | Singer Sewing Machines
Tip
How to disassemble a washing machine
The washer cabinet usually must be disassembled for repairs and some maintenance. The washer is connected to both the electric power outlet and to the water supply. Make sure the power cord and water hoses are disconnected before you disassemble the cabinet or tip it over for service. To disassemble a washer:
-To remove the control panel, remove retaining screws spaced around the panel. They are usually located under a piece of molding or trim that can be pried off. On some machines, you'll have to remove the back of the control panel, also held by retaining screws, to get at the working parts of the controls. Knobs on the control panel are usually friction-fit and will pull off. Some knobs are held by small setscrews at the base of the knob. Loosen the setscrews with a screwdriver or Allen wrench and pull the knobs straight off the shafts.
- To remove the service panel, remove its retaining screws, then spread an old blanket on the floor to protect the washer's finish. Make sure the machine and hoses are drained of water. Tip the washer over on its front or side to gain access through the bottom of the machine. The bottom of the machine generally doesn't have a service panel because it is usually open.
- To remove the top of the cabinet, insert a stiff-bladed putty knife into the joint between the top and side panels and give the knife a rap with your fist. This should release the spring clips so that the top can be removed.
on Jan 16, 2010 | Washing Machines
How to disassemble
The entire tension assembly will come out intact. There should be a screw (usually about 8-9 oclock) that holds the unit in place. Loosen it and pull assembly out. There will be another screw that holds the big round part (that was back in the machine before removing). Loosen and slide off, then remove and replace spring. Make sure when you install that its not in too far that it keeps your tension discs open all the time or you won't be able to adjust the tensions.
Aug 06, 2014 | Consew CN2053R1 Sewing Machine
How do I disassemble the boiler of an Illy X-1?
If you want to disassemble the boiler you must have opened the machine. There are screw heads around the boiler and it opens fairly easily.
Feb 23, 2014 | FrancisFrancis! X1 - Stainless Steel...
Nespresso d300 leaking
The disassembly is a bit tricky as there are some screws with oval heads that require special tooling.
The web site below has tons of useful information on how to do it and where to find the special tool for the oval-head screws.
http://maultech.com/chrislott/blog/20100627_nespresso.html
The tool is available on ebay for about $10.
http://www.ebay.com/itm/Nespresso-Krups-Service-Repair-Tool-Open-Security-Oval-Head-Screws-/121114184054
I managed to disassemble it by cutting a slot for a flat-head screw driver in the oval screws using a Dremmel tool.
Most of the screws that you have to remove are on the back of the machine. There are three special oval head screws + four torx-head screws + two Phillips screws on the top of the machine.
Feb 06, 2014 | Nespresso D300 Espresso Machine
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
Disassemble ena 4
As far as I know the Jura machines have a special oval shape screw head on their panels...and Jura charge something outrageous like 150euro if you want to buy the tool for opening these! Mite be worth trying to open it some other way like by gluing a tool or something into the head and let it dry, then open it.... then maybe replace the oval head screw with a different screw type when reassembling. Not an easy method of getting past the problem but id sooner do it than pay for the tool!!
Hope this helps
Dec 04, 2012 | Jura Capresso ENA 4 (13421)
I am replacing the water inlet valve. How do you open the top the machine?
There is no way to open the "top" of the machine, only the rear panel, lower "kick" panel or back plate (behind the timer mechanism). These water inlet valve can be accessed by moving the appliance away from the wall, removing a dozen screws and lifting out from the tabs. Most washers are repaired from below or the back, almost never the top or front. There is a chassis for the motor, but only the backs of the upper and lower areas are removeable without complete disassembly. Don't attempt to disassemble the entire thing--EVER! When in doubt, look for an online schematic, usually provided (as a PDF) by most manufacturers online. Exploded views as well.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do I disassemble a Brother sewing machine? I have it almost open but one part, below where you wind the bobbin, will not come apart. Part of a screw that holds a piece in place fell out while trying...
Disassemble your home sewing machine for routine maintenance Many sewing machine repairs can be made at home, and most repairs can be completely avoided through routine sewing machine maintenance. This tutorial shows you how to carefully disassemble your machine to give it a round of maintenance. You will need a screwdriver - make sure not to lose any of the screws! How to Disassemble your home sewing machine for routine maintenance
Oct 11, 2017 | Brother Sewing Machines
Solis Crema SL-70 Espresso Machine Logo
526 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
