Question about Daewoo Televison & Video
Auto program without remot - Daewoo Televison & Video
How to auto. program. pv7400 VCR without. remote
You must have its remote control to do an auto-program.
Oct 27, 2013 | Televison & Video
Programming a TV without remote
You must have its remote control to program this TV.
Feb 17, 2013 | Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Can you auto program a old phillips flat tv without a remote control?
Only if you have a menu button on the TV. But you can buy an generic remote and program it and then you can have a romote you can use. Good luck,
Shawn
Jan 30, 2011 | Televison & Video
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How to get to menu without remote
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
Jun 03, 2010 | Panasonic PV-M2089 Combo
Trying to hook up the tv to direct tv, don't have remote and cannot get tv on to channel 3
The only work around you have without a remote is sloppy. If you are patient, give it a go: connect the box to the TV (cable/ant input), turn on the direct TV box, using the TV button panel (here comes the sloppy) fumble your way to the auto-program menu, start auto program. When the auto-program is done, you will have just CH 3 memorized, so the CH -/+ button will only go to that channel. Worst part will be figuring out the buttons on the TV... it can be frustrating. It may take a few tries, that's why I call it sloppy. I hope this was useful, best wishes.
Apr 19, 2010 | Insignia NS-24 TV TV
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Cannot set up TV.We bought floor model without remote or manual.We need to auto program channels without remote
get the original remote for the set. You won't be able to do the menu functions without it.
C-Dog
Feb 10, 2008 | Televison & Video
Need an Instruction Manual for a Hitachi Video Deck Model #VTM181A(R)
any universal remote will do.
hit menu on the remote and go into setup.
next make sure it is set on catv1
then select catv1 and auto program
fallow the promts
Nov 18, 2007 | Hitachi Televison & Video
Televison & Video Logo
24 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
