Question about Blenders
Blender won't turn on - Blenders
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
Magic bullet
Blenders usually have some sort of interlock that prevents power from being turned on if the container is not locked in place. This could be the reason for the problem
Apr 25, 2013 | Emson Magic Bullet Express Blender
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
Kitchenaid ksb560 won't turn on. No power at all...
Take the base off and check the motor for continuity.
Jan 08, 2012 | KitchenAid KSB560 5 Speed Blender
My blender is leaking slightly from underneath the blade. Is there a way to tighten the blade coupling?
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
May 04, 2011 | KitchenAid KSB560 5 Speed Blender
Blender has power but won"t turn on
Hello and Welcome to FixYa!
Well the mal-function can be due to numerous reasons. You need to choke out each possibility one by one.
Loose Connections ( Check for all the connections to the circuitry and motor). Bad Starter Button ( Check for the button switching using a Multi meter). Bad Motor Winding (Motor bushes or winding can be the bottle neck).
Check for the quoted possibilities and you'll soon find one good reason for the mal-function.. Feel free to ask anything regarding the trouble.
Concerned.
Feb 25, 2011 | Waring 7011S / 7011G Commercial Work Top...
BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
May 16, 2010 | Wolfgang Puck BIBC1030 Blender
Blenders Logo
59 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
