Question about Harman Kardon AVR 100
Harman Kardon AVR 40 no sound
Harman Kardon AVR 40 was working just fine for quite a while, and then about 3 or 4 times in a row, when I switched to the audio channel that I wanted (CD or TV usually), a strange sound came through the speakers and then nothing.  Now no strange sounds come through, and it does nothing at all.
I've tried all the inputs, all the speaker outputs, taken the cover off and vacuumed/blown the dust away, and tried to see if there were any obvious problems.
Any other ideas?
  • 1 more comment
  • osprey Nov 06, 2007
    mine is a hk AVR 35. i know very of electronics. i can turn the volume control when this problem occurs and it will work for a few minutes and start again. it sounds like a short to the speakers. i'm looking for a repair facility in the fort worth texas area. e-mail adress is mlafon @ charter . net thanks for the web site.
  • stierzy16 Jun 18, 2008
    Yeah i have a Harman Kardon Avr 100 and when ever i turn it on it just turns off automatically. I did that twice and then about in the back center of it ( if you look at it straight down) something went pop then a little bit of steam came out. so i'm guessing it's the fuze.
  • Anonymous Mar 31, 2014
    When using surround sound with verizon fios the sound breaks up
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Posted on Sep 06, 2008
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
My center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Oct 07, 2009 | Harman Kardon AVR 40
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Harman Kardon AVR 100 Logo
2,838 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
